    Simple filament sensor detection delay?
    • norbs12
      norbs12 last edited by
      Using an optical end stop and randomly getting false runouts. Is there a way to add a delay before triggering the pause?
      I'm not seeing anything in the documentation under M591.
        Do you mean a simple slotted optical switch, with the filament blocking the light path? If so then you probably need to constrain the filament more tightly to be in the centre of the slot. Capricorn tubing is good for this.
        • norbs12
          OK thanks. Are you expecting to release the laser filament sensor to the public any time soon?
            dc42 administrators @norbs12 last edited by
            @norbs12 said in Simple filament sensor detection delay?:
            Yes, we're having 50 of them assembled.
            • norbs12
              Awesome, where can I order one?
              • timcurtis67
                timcurtis67 last edited by
                I defiantly want 2 as soon as they are available.
                • T3P3Tony
                  T3P3Tony administrators @norbs12 last edited by
                  The 50 we are having assembled are initially for internal testing. Then beta testing. Sorry for the delay in releasing these but I need to qualify them across a wide range of filaments.
                  www.duet3d.com
