    Error: M24: Cannot resume while power voltage is low
    • DR8
      DR8 last edited by DR8
      I have a duet wifi board with this configuration:
      Firmware Version: 2.0(RTOS)RC5 (2018-05-22b1)
      WiFi Server Version: 1.21
      Web Interface Version: 1.21.1-RC4
      I have installed a Runout filament sensor. It's an endstop. After it triggers, I insert a new filament and when to press Resume, I got this error:
      The input voltage on the board is fluctuating between 11.7 and 12.2V. This error occur even if I intentionally press the Pause button.
      • T3P3Tony
        T3P3Tony administrators @DR8 last edited by
        @dr8 have you got M911 in your config.g?
        https://duet3d.dozuki.com/Wiki/Gcode#Section_M911_Configure_auto_save_on_loss_of_power
        www.duet3d.com
        • DR8
          DR8 last edited by
          Yes I do. Here's the line from my config.g
          M911 S20.5 R22.0 P"G91 M83 G1 Z3 E-3 F1000"
          • DR8
            DR8 last edited by
            Oh s..t,
            Now I see the problem.I have another duet on other printer witch is on 24V. Jeez, I'm gonna loose my head one day. Thaks a lot.
            T3P3Tony 1 Reply Last reply Reply Quote 1
            • T3P3Tony
              @dr8 Glad it was an easy fix.
              For anyone else seeing this the M911 S voltage level needs to be met for resume to work.
              www.duet3d.com
