    Add brake to Z axis
    • Jddt
      Jddt last edited by
      As I am using a different configuration on my Z axis I need to add a brake to hold the Z axis in position if there is no output to the Z motor. Can a IO be configured on the Duet WIFI to be used to control an external brake/realay when there is no voltage send to the Z motor, will not hold the Z axis.
      mrehorstdmd 1 Reply Last reply Reply Quote 0
      • T3P3Tony
        Are you using the onboard stepper drivers or an external driver?
        There is an explanation in this thread of a way to do this:
        https://forum.duet3d.com/topic/4587/vertical-axis-brake/3
        • Jddt
          Jddt last edited by
          I am using the expansion board with external drivers.
            dc42 administrators @Jddt last edited by
            @jddt said in Add brake to Z axis:
            In that case I suggest you either use the ENA+ or ENA- output to activate the brake when the Z motor is not enabled, or add a dummy Z driver on driver 10 or 11 as described in the thread that Tony linked to.
            • mrehorstdmd
              mrehorstdmd @Jddt last edited by
              @jddt
              I use belts to lift the Z axis in my printer. I solved the bed-drop-on-power-off problem by installing a worm gear drive. If the gear ratio is sufficient (and/or the pitch of the teeth is right), the mechanism is irreversible and no brakes are needed to hold the bed.
              My printer's bed assembly weighs about 3.5 kg and does not move unless the motor tells it to move.
