    Noctua 5v 40mm fan only running at max power
    1326
    • bartolomeus
      bartolomeus last edited by
      Today I received two of these: https://noctua.at/en/products/fan/nf-a4x20-5v
      and connected them to the Duet. They work, however they only run between 97-100% power. Anything lower and they stall. Did I miss something or was this to be expected?
        How do you have them connected?
        bartolomeus 1 Reply Last reply Reply Quote 0
        • bartolomeus
          @phaedrux With only 5v and ground connected.
          • bartolomeus
            bartolomeus @Phaedrux last edited by
            This post is deleted!
              You said you're running two of them, are they connected in series, or in parallel?
              • bartolomeus
                @phaedrux None of both. One is layer fan, other is hotend fan.
                  You can try varying the PWM frequency or adding a blip time of full speed. some fans won't start at low speeds without a true PWM signal.
                  Those fans are very quiet. Is there an issue with running them at 100% power? For the layer fan when printing PLA that probably wouldn't be an issue since it's not the most powerful fan to begin with.
                  For a good controllable 5v blower Sunon has some good options.
                  • bartolomeus
                    @phaedrux I agree it probably won't be a big problem for the layer fan. It really doesn't move that much air. I needed my printer to make less noise as its in the living room and this seemed like a good option. However I really doubt it moves enough air..... I'll have a look at the sunons.
                      I use the 12v version of that fan for my hotend fan and it seems to perform alright.
                      • bartolomeus
                        @phaedrux you mean you have the sunon or the noctua for the hotend?
                          Phaedrux Moderator @bartolomeus last edited by
                          @bartolomeus Sorry, I meant to say, I use the 12v version of the Noctua 40mm you are using on my Titan Aero and it seems to work fine. I use a 12v Sunon blower fan for the part cooling, but it's not exactly quiet above 50%. However it does have a very wide usable PWM range, which makes it flexible. Sunon also makes 5v versions of blowers which are quite good.
                          • bartolomeus
                            @phaedrux thanks for the tips. I am not worried about the hotend fan. I'll see how it performs as layer fan. If it doesn't do well, I'll look for something else.
                              Try varying the PWM frequency as @Phaedrux suggested. In particular, try reducing it.
                              bartolomeus 2 Replies Last reply Reply Quote 0
                              • bartolomeus
                                bartolomeus @dc42 last edited by
                                @dc42 Thanks. It's on tomorrow's to-do list, including the blip time.
                                • mrehorstdmd
                                  mrehorstdmd last edited by mrehorstdmd
                                  Since the subject is quiet fans here, I recently bought a hot-end via Ali-express and it came with a 24V cooling fan. That fan is about as quiet as the Noctua fan on the Prusa i3 at the makerspace. I know the Noctua fans aren't available as 24V units, so if you're looking for a dead quiet 24V fan you can get them here
                                  I haven't had the unit in my printer for long, so I can't say anything about reliability.
                                  Unlike most of the inexpensive stuff from China, these things have actual data sheets with real specs.
                                  • bartolomeus
                                    @dc42 said in Noctua 5v 40mm fan only running at max power:
                                    Ok, so did that:
                                    at 25,100, 1.000hz and there was no difference
                                    tried 25.000 as that is suggested for PWM fans (which this one is not), and now it starts at about 35% power.
                                    Should I leave it at this, or look further?
                                      Try lower, e.g. 100. High frequencies such as 25000 should only be used with 4-wire fans.
                                      • bartolomeus
                                        bartolomeus last edited by bartolomeus
                                        I did try lower. 25, 100, 1000, with no effect
