    New beta Duet WiFi firmware bundle
    Firmware installation
    8
    32
    5.7k
      Brian & Michael,
      I'm sorry to hear that you have both been experiencing problems since installing new firmware. If you want to revert to the original firmware that was installed on the pre-production boards when they were shipped, you can find it here: https://www.dropbox.com/sh/lf9sgndzmoiepas/AACn6NS8GuPjvoikQ7xF8zY6a?dl=0.
      If that gets it working well again over an extended period of time, please try upgrading either the main firmware (DuetWiFiFirmware.bin, installed using M997 S0) or DuetWebControl.bin (installed using M993 S2) and see if it is still reliable.
      If you encounter any instances of web interface disconnects and then you find that you can't reconnect, then first try closing the browser tab and connecting in a new one, in case DuetWebControl has got into a state it can't recover from. If that doesn't work, then if possible open your router's status page showing connected wireless devices, and see if the Duet WiFi is still connected. Currently, if your router kicks the Duet off the network, it won't attempt to reconnect unless you stop and re-start the WiFi module. I will fix this in the next DuetWiFiServer release.
      • briangilbertundefined
        briangilbert
        I just tried again and for some reason SAM-BA worked this time.. was able to reflash with the beta version and PanelDue and the web interface are connecting now! 🙂
        Co-creator of the Zesty Nimble direct drive extruder
        • Huguesundefined
          Hugues
          This new version works well for me (window 7 64b).
          There is a little bug in the duet web control, it's not possible to replace a file even if you delete it before trying to upload it.
          I've to rename it. Deconnecting from the session doesn't solve this for me.
            briangilbert
            I'm still getting web interface ajax timeouts with this version.
            • roboduetundefined
              roboduet
              Can somebody try to dump network traffic using Wireshark to and from DuetWiFi board with this ajax timeouts issues?
              • mhackneyundefined
                mhackney
                All, when you get the ajax timeouts can you please report if you are able to reconnect or if you have to reset/reboot the Duet board please. In my case, once I get the timeout I can not reconnect even if I try from a completely different browser or computer.
                I am doing a fresh re-install of the original pre-production binaries as I type and I will capture the network traffic with Wireshark too.
                My 3D Printing blog: http://www.sublimelayers.com
                Coming this summer: "3D Printing Strategies - the art of perfecting your designs and prints"
                • mhackneyundefined
                  mhackney
                  All, I have reverted back to the pre-production code and captured a complete trace with Wireshark. The link to the trace and details are on my thread here: https://www.duet3d.com/forum/thread.php?pid=578#p578
                  • Huguesundefined
                    Hugues
                    I get more problem of ajax time out, usualy i can reconnect but few minutes ago i had to unplug the printer due to an emergency !
                    How to use wireshark ? I installed it but i do not know what to enter…
                    I 'm getting this time out mainly when i upload a file to the printer. I've to redo the upload with a new file name otherwise it doesn't work. Also i notice it crash when the upload didn't start at full speed.
                    • mhackneyundefined
                      mhackney
                      Learning how to use Wireshark is not terribly difficult. Basically, after launching you need to select the interface to watch - in this case, WiFi. Then you need to apply a filter for IP address to capture traffic from, otherwise you get a lot of extraneous info. You can just capture everything and we can filter out stuff from the log too but I prefer to set a filter. My filter looks like:
                      ip.addr == 192.168.1.242
                      Your IP will be different (your Duet WiFi IP - get it from Pronterface when you issue a M552 S1)
                      By the way, I have discovered that once I get the comm failure I can turn off and then turn on WIFI in Printerface and it will reconnect:
                      M552 S0
                      M552 S1
                      I get the time out even if I connect and just sit there and watch with no activity. Try that and see what happens, I bet you'll timeout too.
                        briangilbert
                        I am able to reconnect, however I get dropped again after not too long (particularly when in the middle of a print).
                        • Huguesundefined
                          Hugues
                          I installed and get wireshark listening my duet, to be sure i reinstalled the last bundle firmware but no timeout connection since 10min
                          • RichRap3Dundefined
                            RichRap3D
                            No problems with the update for me, all installed fine.
                            The print motion looks different to me, I can't quite put my finger on exactly what it is, but almost like accelerations have slowed down very slightly or maybe smoothed, but it may be just be me remembering what it was like in the last release.
                            Anyone see or 'feel' and difference?
                            Producing very good print results, so I'm happy.
                            Cheers,
                            Rich.
                            • Huguesundefined
                              Hugues
                              I cannot confirm that the motion is slower in this new version but i notice a hudge difference when the model is like a low polygonal model with straight path than a curvy model. My extruder was clicking at 200mm/s on the polygonal and i've to slow down to 150 to get it work correctly, the hotend temperature was insanely high for PLA and on the curvy model with near the same loop length and without short curve, no problem.
                              Did you feel this on the same model ?
                              • Aussiephilundefined
                                Aussiephil
                                I've upgraded without any obvious issues and been connected on and off for 6 hours so far via the web page though no actual prints yet 🙂
                                Upgrade was done via the web page for all the modules without any issues.
                                Cheers
                                Phil
                                • mhackneyundefined
                                  mhackney
                                  David, I've been keeping statistics on disconnects the last few of days and been monitoring my network for the last day. Firstly, the original network issues that were antagonizing my original issue are gone so that is no longer a factor.
                                  My other 5 deltas are running Duet with a TP-Link wifi bridge and Duet Wifi are all on the same network. The other 5 are running 1.09z-ch firmware and 1.11 HTML and JS.
                                  In 72 hrs I've had 1 of the 5 disconnect one time but the other 4 have stayed connected (both printing and sitting idle over night) for 3 days.
                                  The Duet WiFi has disconnected 8 times in the same time period. The good news is, a simple click of Connect and it reconnects quickly.
                                    Michael, can you confirm that you are running DWC 1.11b-dc42 on the Duet WiFi?
                                    One of the items in the firmware plan is to rewrite the web server running on the ESP, using the Duet web server as a basis. That will hopefully reduce the disconnection rate further.
                                    • elmoretundefined
                                      elmoret
                                      This update seems to have resolved the timeout problem for me, 4 hours in without a disconnect.
                                      How is the notification timeout supposed to work? Mine still don't auto-dismiss. Is it possible to make an option in the settings that when selected only shows the most recent notification instead of filling the whole browser window?
                                        briangilbert
                                        If I'm having to copy the DuetWiFiServer file onto the SD card by plugging it into my computer, what command do I need to run to ensure it gets installed?
                                        • mhackneyundefined
                                          mhackney
                                          David, I'm running 1.15-beta3 (2016-07-09) firmware on Duet WiFI
                                          This machine has disconnected 3 times in the last 24 hrs since my report yesterday. My other 5 deltas running earlier Duets have not disconnected in the last 24 hrs. So to recap 96 hrs (4 days) I've only had 1 disconnect on a Duet 0.6 with a wifi bridge out of 5 printers total so:
                                          Earlier Duets with WIFI bridges: 1 disconnect in (96hrs * 5 printers) = 1 disconnect in 480 hrs
                                          Duet Wifi: 11 disconnects in 96 hrs
                                          • elmoretundefined
                                            elmoret
                                            Update: 12 hours in, no disconnect error. Definitely the longest I've gone without a disconnect timeout, thanks David!
