    Extruder Stepper suddenly only vibrates
    2.5k
    • Floundefined
      Flo
      After printing several spools successfully, suddenly E0 only vibrates on my CoreXY.
      I tested multiple Steppers, known good cables etc.
      Switched cables to working E1, which now shows the same behaviour as E0 (worked fine before, works if I up it to 800ma on E1, still not on E0).
      Even switched Duet Wifi to another one, works with my delta config, doesn't work with the CoreXY
      esteps are for a Nimble, in case you are wondering...
      Config below:
      ; Configuration file for Duet WiFi (firmware version 1.17)
      ; generated by RepRapFirmware Configuration Tool on Sat Oct 07 2017 22:26:24 GMT+0200 (CEST)
      M111 S0 ; Debugging off
      G21 ; Work in millimetres
      M667 S1 ; Select CoreXY mode
      M208 X230 Y220 Z320 S0 ; Set axis maxima
      M574 X2 Y2 Z2 S1 ; Define active high microswitches
      M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
      G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:214 Y15:242 S20 ; Define mesh grid
      M569 P4 S0 ; Drive 4 goes forwards
      M350 X16 Y16 Z16 E16:16 I0 ; Configure microstepping without interpolation
      M92 X80 Y80 Z640 E2740:2740 ; Set steps per mm
      M566 X1500 Y1500 Z12 E5000:5000 ; Set maximum instantaneous speed changes (mm/min)
      M203 X24000 Y24000 Z180 E5000:5000 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z450 E2500:2500 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E350:350 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M143 S260 ; Set maximum heater temperature to 260C
      M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2
      M563 P0 D0 H1 ; Define tool 0
      M563 P1 D1 H2 ; Define tool 1
      G10 P1 X-18 Y0 Z0 ; Set tool 1 axis offsets
      G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
      M550 PCorexy ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      • sigxcpuundefined
        sigxcpu
        Maybe that is not the problem but:
        2740 steps/mm * 5000 mm/min = 13700000 steps/min = 228333 steps/second for the extruder.
        Are you sure that's what you want?
          The usual causes of stepper motors just vibrating are:
          • Bad crimp connection in the stepper motor cable (most common)
          • Stepper motor wired not paired in the correct phases (but it used to work, so not this reason)
          • Failed driver on the Duet (but you have already changed it, so not this reason)
          • Failed motor (least common)
          • Floundefined
            Flo
            @sigxcpu said in Extruder Stepper suddenly only vibrates:
            That is max feedrate, I am testing at 5 and 10mm, so I will not even reach that limit.
            @dc42 said in Extruder Stepper suddenly only vibrates:
            I tested with 4 different known good cables, so it seems kind of improbable
            Tested each of them with the motor before plugging in an they are wired correctly
            Tested with 3 Steppers by now, unlikely.
            OK, tested something different as well:
            I did plug in the CoreXY config SD into another printer and it doesn't work. Plugging in the normal config works fine...
            So I think this means it's not the cable, stepper or driver, but the config or FW?
            I could try to update the FW to the newest version
            • T3P3Tonyundefined
              T3P3Tony administrators @Flo
              @flo was the other test printer also setup to use the same driver to run E0. Did it fail in the same way (vibrating driver?) in that case it sounds like the current is too low.
              www.duet3d.com
              • deckingmanundefined
                deckingman
                If I understand correctly, it was all working fine and then suddenly stopped working yes? Did you make any changes between when it worked and when it stopped working, including changes to firmware? If the answer is no, then the cause is unlikely to be firmware unless the file(s) have got corrupted somehow (unlikely). You get the same behaviour using different driver chips, different motors, and different cables yes?
                If the answer to all the above are yes, then the only common denominator is the hot end itself. i.e. you have a blockage and the extruder can't push the filament against this blockage so it "vibrates". The other alternative might be something mechanically wrong with the nimble causing it to bind, stick or otherwise not rotate, but I have no experience of these so can't comment further.
                • Floundefined
                  Flo
                  @deckingman said in Extruder Stepper suddenly only vibrates:
                  I did not make any changes to config or Firmware.
                  I did check the extruder for blockage and everything worked fine, until I applied power.
                  This applied to any stepper I connected, even without any load on it.
                  I just created a new config and everything works now, seems the config got somehow corrupted in between or the SD had a bad sector.
                  • Floundefined
                    Flo
                    This post is deleted!
                    • Knaudlerundefined
                      Knaudler
                      hi
                      wich extruder needs 2740 steps/mm ?
                      I'm using an Bondtech BMG - needs 410 steps (with I1)
                        deckingman @Knaudler
                        @knaudler said in Extruder Stepper suddenly only vibrates:
                        hi
                        He said it was a Zesty nimble. Those sort of flex drives have a lot of gearing.
                        • Knaudlerundefined
                          Knaudler
                          Zesty nimble
                          ok, thanks
