Burnt cable from 5v
Hi guys,
i connected the bltouch incorrectly by accident, from which point my cable coming from the 5v had started getting hot,Now the servo on the touch doesn't work and the BLtouch only goes into error.
when using the m280 command to deploy the pin, it doesn't do anything.
Have i destroyed something on my BLtouch or have i destroyed something on my duet.
Please Help
@npm1 did you connect to the 5V pin on the expansion header? If so then it's most likely that the BL touch is damaged but hopefully not the Duet. Is the Duet working correctly otherwise?
