    Panel Due & DuetWifi Cockpit
    PanelDue
    • heapstarundefined
      heapstar
      For the Panel Due 7" I have designed a cockpit which integrates DuetWifi also. It is supposed to be used with 60x20mm I5 extrusions but you might cut the STL to your needs or use the Onshape CAD files for variations. For example you might surpress the "NXD evo" or change it to your super dooper printer name.
      0_1530405010331_cockpit.JPG click pic for CAD
      0_1530393757734_cockpit2.JPG click pic for CAD
      ->STL
      Have fun with it 🙂
      Gruß
      Niko
      T3P3Tonyundefined JoergS5undefined 2 Replies Last reply Reply Quote 4
      • bitwizzardundefined
        bitwizzard
        Cool great work! Thank you for shareing!
        • T3P3Tonyundefined
          T3P3Tony administrators @heapstar
          @heapstar Looking good, cheers for sharing the design,
          www.duet3d.com
          • JoergS5undefined
            JoergS5 @heapstar
            @heapstar That's a nice design, thanks a lot. I'll try to modify it (I want an SD card access in the front) and try it.
