    Can't Home Z with a Z Probe installed
    2.2k
    • Vaeiundefined
      Vaei
      I recently connected an EZABL and everything is working - when I put my finger under it, it's triggered.
      However I can't home Z.
      I read the guide here and specifically "Homing Z using a Z probe": https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z
      It's illogical to me because it tells you to G30 to effectively home the Z using the probe but G30 can't run without Z homed. What do I do?
      I tried using M574 to set Z end stop to use the probe but that didn't work either.
        G30 needs X and Y to be homed first, but not Z.
        • Vaeiundefined
          Vaei
          X and Y are homed yet the error still occurs. What does it need?
          • Vaeiundefined
            Vaei
            This is my config.json for reprapfirmware configurator if that helps
            https://drive.google.com/open?id=12VJ0j6iLhLLwgAJG4DQbLxDPtQtFVlSx
              Can you post your config.g and your homing files?
              • Vaeiundefined
                Vaei
                @phaedrux said in Can't Home Z with a Z Probe installed:
                Sure
                https://drive.google.com/open?id=15q-ReiRuzfv0u6V4hmQRy1bwbsqbV75e
                  Phaedrux Moderator @Vaei
                  @vaei unable to access your drive
                    dc42 administrators @Phaedrux
                    Same here.
                    • Vaeiundefined
                      Vaei
                      That's odd somehow the public sharing turned off
                      <edited to remove the link>!
                        @vaei I don't think you meant to link that.
                          I'm not sure if it matters, but you have your M574 command set to use a Z endstop currently.
                          Try changing that to M574 Z1 S2 ; Use zprobe and home to Z Min.
                          I say it may not matter because in the next few lines you specify the z probe in M558.
                          Your Homeall.g looks ok.
                          Your Homez.g won't work unless XY and already homed or you add S2 to your G1 move to get the probe in position.
                          Vaeiundefined 1 Reply Last reply Reply Quote 0
                          • Vaeiundefined
                            Vaei @Phaedrux
                            Thanks for the help 🙂 Unfortunately the same thing occurs.
                            By the way, does the reprap configurator have a setting for Mode 5? None of them have their mode numbers shown and it's 5 that works for mine. The others don't see it trigger. I keep having to manually set it after the fact.
                            I thought I uploaded the config.zip - if so what was in it that I shouldn't have linked it? Wifi p/w?
                            Well, I'm more or less at a loss.
                            • T3P3Tonyundefined
                              T3P3Tony administrators @Vaei
                              @vaei said in Can't Home Z with a Z Probe installed:
                              You linked your timesheet spreadsheet which is why i removed the link!
                              the older link works for your config.zip
                              Try adding an S2 after the movement commands in your homeZ and home all.g:
                              G1 X15 Y73.5 F6000 S2
                              You have the EZABL setup as probe type 1, is that correct ( I don't know how it works - capacitive?)? You say it triggers correctly so I will assume it has an analog output, actually i just saw this:
                              Your sharedconfig.g has the mode set to 1 in M558:
                              M558 P1 H5 F120 T6000
                              the RepRapFirmware configurator lets you choose the type of Z probe:
                              With it set to "switch" I get "M558 P0.." which is wrong it should be P4 or P5. Thanks for finding this bug - I will report it to @chrishamm
                              www.duet3d.com
                              • Vaeiundefined
                                Vaei
                                I got it triggering correctly with Mode 1 but I need to set I1 with M558 also for it to work.
                                Unfortunately I still can't home, even after the changes adding S2.
                                  What do your config and homing files look like now?
