    DWC 1.21.1 and DWC 1.22.1B2 bugs
    Duet Web Control wishlist
    1092
    • Jbourns
      Jbourns last edited by
      F/w version is 2.01b1, web server is 1.21.1 iirc
      Im running into a few bugs with DWC.
      On 1.21.1 the web interface doesnt show that the printer is homed, it will still display that the axis aren't homed even after homing plus it wont show were the print head is in the top right, it only shows zeros.
      Tried updating to 1.21.2b2 to see if that would fix it.
      It does fix the issues mentioned on 1.21.1
      But when i jog the print head, it behaves as if it a Cartesian printer only moving diagnally.
      sending a move command for example G1 X200, X will move as expected .
      0_1530823261491_config.g
      • T3P3Tony
        T3P3Tony administrators @Jbourns last edited by
        @jbourns thanks for the report. I have moved this to the DWC area. I know @chrishamm is working on another beta release of 1.2.1.2 b2
        In the mean time it might make sense to revert to the last stable release of both.
        • Jbourns
          Ok thanks for the heads up. I'm back on dwc 1.21.1 , ill downgrade the f/w to 2.0
          I'll post if it makes a change
          • whosrdaddy
            whosrdaddy last edited by
            I have to report another bug (coming from 1.21).
            CoreXY printer, M564 H0 in config.g.
            Cannot jog any unhomed axis (also setting "allow moves if axes are not homed" does not help)
            looking at the code (interface.js) :
            if (lastStatusResponse != undefined && lastStatusResponse.coords.axesHomed[axisIndex]) {
            		var moveString = "M120\nG91\nG1 ";
            		moveString += axis + $(this).data("amount");
            		moveString += " F" + settings.moveFeedrate + "\nM121";
            		sendGCode(moveString);
            DWC will only send G91 if the axis is homed irrespective of what I tell the firmware?
            Send G91 from gcode console obviously works but is a bit of a hassle.
            for completeness, current firmware:
            Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
            Firmware Electronics:	Duet WiFi 1.02 or later + DueX5
            Firmware Version:	2.01(RTOS) (2018-07-26b2)
            WiFi Server Version:	1.21
            Web Interface Version:	1.22-b1 (latest from dev branch on GitHub)
              This is a known issue, which I fixed in DWC 1.22-dc42 (available at https://github.com/dc42/RepRapFirmware/releases/tag/2.01). I expect Chrishamm has fixed it in his more recent releases of DWC too.
              • whosrdaddy
                @dc42 : the code I showed is from latest version on the DWC dev branch.
                  Have you tried 1.22-dc42 ?
                  • deckingman
                    deckingman @dc42 last edited by
                    @dc42 Where do I find DWC 1.22-dc42 David? The link above only shows 1.21.2-dc42. For info, that version worked fine with my CoreXYUV but ChrisHam's 1.22 b2 won't let me move axes unless homed. I've pointed that out to Chris in another thread https://forum.duet3d.com/topic/5485/duet-web-control-wishlist-notes-and-priorities
                      dc42 administrators @deckingman last edited by
                      @deckingman said in DWC 1.21.1 and DWC 1.22.1B2 bugs:
                      In the RRF 2.01 release area, https://github.com/dc42/RepRapFirmware/releases/tag/2.01.
                      • Dougal1957
                        Dougal1957 last edited by Dougal1957
                        David thats 1.21.2-dc42 not 1.22 as far as I can see anyway else I am blind
                          I'm sorry, I got confused with version numbers. I meant 1.21.2-dc42.
                          • deckingman
                            @dc42 Ahh good - I thought it was me going crazy or blind. ☺
                            So, I can confirm that axes can be moved in DWC 1.21.2-dc42 but not in Chris Ham's very latest 1.22-b2. I've pointed this out to him in the other thread.
                            • chrishamm
                              chrishamm administrators last edited by
                              Should be fixed in v1.22-b3.
