    Duet Web Control wishlist notes and priorities
    32
    116
    11366
    • chrishamm
      chrishamm administrators last edited by
      As some of you may have noticed I did some moderation in this forum a few days ago and locked requests that are either duplicates, impossible to implement or those that have already been implemented. If you wish to have a certain feature added to the web interface, please vote for it in the corresponding thread.
      If you think it was a wrong decision to lock a specific thread (e.g. because an important feature is still missing), please feel free to open a new one or contact me directly via PM. Please be aware that I locked those threads in order to clean up the list of requests and not to cause frustration among users.
      As I expect to rewrite a main part of DWC in the near future I have not focused on better UI customisation yet but I am planning on improving this aspect greatly when I rewrite more of the underlying code.
      To give you an idea what will be implemented soon, here a list of the features that I will focus on over the next weeks. I will implement point by point and update this thread after every update - you'll be able to check out the new features on my dev branch too (see https://github.com/chrishamm/DuetWebControl/tree/dev) :
      • G-code input history (https://forum.duet3d.com/topic/1631/detailed-print-history)
      • G-code visualiser (depending on whether I can get a good visualisation toolkit working in JS) (https://forum.duet3d.com/topic/141/gcode-visualizer)
      • Different icons for the babystepping buttons (https://forum.duet3d.com/topic/3963/changeable-z-babystep-icons)
      • Ability to change increments for all the movements buttons (https://forum.duet3d.com/topic/288/duet-web-control-change-wish-list/2)
      • Better detection of emergency stops/firmware resets (https://forum.duet3d.com/topic/4054/automatic-reconnect-after-reset/4)
      • Highlight currently active tool (https://forum.duet3d.com/topic/2204/more-prominent-way-of-showing-active-tool)
      • Add S2 parameter to G1 movement codes (only as an option to be chosen in setup) (https://forum.duet3d.com/topic/4333/add-s2-parameter-to-head-movement-button-g1-actions)
      • Parse last G29 code and determine if different heightmap file was specified (https://forum.duet3d.com/topic/5105/auto-display-saved-heightmap-file)
      • Ability to change movement/feedrate button increments (https://forum.duet3d.com/topic/288/duet-web-control-change-wish-list/2)
      deckingman robm 2 Replies Last reply Reply Quote 6
      • BenDiesel
        BenDiesel last edited by BenDiesel
        One thing noticed is with the panel.due there is no " on the onscreen keyboard. Kinda make it hard to setup wifi with it
        deckingman dc42 2 Replies Last reply Reply Quote 1
        • whosrdaddy
          whosrdaddy last edited by
          • better alternative for sliders on mobile UI (on smartphone they are impossible to control in a precise manner)
          • DocTrucker
            DocTrucker last edited by
            Add a report on the gcode page to show when a file has been simulated and the time result.
            The firmware adds the simulated time to the end of the file. You and dc42 may wish to consider getting the firmwate to add a checksum to that so there is a degree of confidence the file hasn't neen changed sine the simulation.
            • denke
              denke last edited by
              @chrishamm Can you give us some more info on what the rewrite changes?
              As a feature request I'd ask for decreased resource consumption, in the current state it's quite a good excercise to my notebook: model name: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz (no offense intended, the current one is very nice in almost every other vay ๐Ÿ™‚ )
              robm 1 Reply Last reply Reply Quote 0
              • deckingman
                deckingman @BenDiesel last edited by
                @bendiesel said in Duet Web Control wishlist notes and priorities:
                I don't think panel.due is anything to do with Duet Web Control or Chrishamm. I think that's DC42s department.
                • deckingman
                  deckingman @chrishamm last edited by
                  @chrishamm
                  Thanks. I for one appreciate your efforts.
                  • whosrdaddy
                    @denke you can decrease the polling in DWC settings, I set my polling time to 750ms and CPU usage was drastically reduced.
                    denke 1 Reply Last reply Reply Quote 0
                    • denke
                      denke @whosrdaddy last edited by
                      Thanks for the tip! Will try!
                        dc42 administrators @BenDiesel last edited by
                        This is OT in this thread, however the current PanelDue firmware does allow you to enter the double quote character. So I suggest you update your PanelDue firmware.
                        • ShadowX
                          ShadowX last edited by ShadowX
                          It would be great to have a single button to zip all the files in the SD Card and download it. I know you can currently download all the system files, but it would be nice to include the other directories to simplify backup process.
                          1. Option to include specific directories (ie: gcodes, macros, sys, www, etc.)
                          2. Option to automatically append the current date and time to the filename to make the names unique
                          If this is not possible, at least having the option to "Download as ZIP" the files in the "macros" folder similar to the system files would be good. When I select all the macro files and folders and right click, there are no options to zip the files to back them up. The only option is to "delete" the files.
                          SnowCrash 1 Reply Last reply Reply Quote 3
                          • SnowCrash
                            SnowCrash @ShadowX last edited by
                            @shadowx said in Duet Web Control wishlist notes and priorities:
                            I think this is an excellent suggestion and would like to second it.
                            • Kulitorum
                              Kulitorum last edited by
                              Ability to change movement/feedrate button increments, please
                              I work with a 8x8x6 meter concrete printer...... 100mm is not very long to move, and 6000mm/sec is just slow af....
                              Kulitorum
                              • robm
                                robm @denke last edited by
                                @denke I think maybe you should look elsewhere for the performance issues? I run DWC on an iMac (20-inch, Early 2008) / 2.4 GHz Intel Core 2 Duo / 4.00 GB RAM. It struggles with most things but DWC doesn't seem to be an issue.
                                • robm
                                  robm @chrishamm last edited by
                                  @chrishamm said in Duet Web Control wishlist notes and priorities:
                                  my prioritised ordering:
                                  I would also like to add:
                                  • more work to remove conditions where setting a temperature in DWC sets the printer waiting for the temperature to be reached ('Busy'). The main ones have been eliminated but I still get this occasionally.
                                  This one (below) may be less important now that there is the G-code to remove the no-move-without-homing limitation overall - or it might be argued that it is better to have DWC and PanelDue use the S2 parameter for 'manual' moves and leave them otherwise disabled until the system is homed:
                                  Thanks for your work Chris.
                                  • Danal
                                    Danal last edited by
                                    I would like to see the message (console) separated by connection, with a small history buffer, perhaps five to eight lines, per connection.
                                    I believe this would take some changes to RR firmware and DWC both.
                                    • Christoph13524
                                      Christoph13524 last edited by
                                      It would be nice to name fans. I have LED strips and other cooling fans installed which is confusing when the names are FAN 1/2/3
                                      • chrishamm
                                        And as promised here the first update, this is the changelog:
                                        • Active tool is better highlighted
                                        • Time on G-Code Console is no longer wrapped
                                        • mplemented auto-completion feature on G-Code inputs
                                        • G-code inputs provide a new link item to the G-code wiki page
                                        • When G29 is invoked with the P-parameter, the corresponding heightmap file is displayed
                                        • Move steps for each axis and extruder amounts+feedrates can be changed via right-click\
                                        • When moving around on the Control page, S2 is added to the G1 code automatically. Can be turned off on the Settings page too
                                        • Bug fix: When the DWC settings could not be loaded from the Duet, defaults are only uploaded if the file could not be found
                                        • Bug fix: Sometimes failed AJAX requests could make DWC stop updating
                                        • Bug fix: Fixed a problem where the A axis could cause a JS error
                                        You can get the new beta here: https://github.com/chrishamm/DuetWebControl/blob/dev/DuetWebControl-1.21.2-b1.zip Please let me know if you find any problems.
                                        zerspaner_gerd wilriker Catalin_RO 4 Replies Last reply Reply Quote 3
                                        • zerspaner_gerd
                                          zerspaner_gerd @chrishamm last edited by
                                          Thank you @chrishamm,
                                          Did not know that there is also a thread about DWC!
                                          Everything is fine
                                          The selection menu I liked but better, as the question mark where the G-code wiki page linked.
                                          1_1529752059749_auswahl menรผ 1.21.2-b1.JPG1.21.2-b1
                                          0_1529752059748_auswahl menรผ 1.21.1.JPG1.21.1
                                          This page I have already created a bookmark in my browser.
                                          • wilriker
                                            wilriker Moderator @chrishamm last edited by
                                            First of all, thank you for the great update!
                                            I like the idea but I would find it even better if this link vould jump to the anchor of an already entered GCODE command. I know this is quite complicated with dozuki's way of creating the anchors but I wanted to state it anyway.
                                            I really like this one! ๐Ÿ‘
                                            • wilriker
                                              wilriker Moderator last edited by wilriker
                                              Firmware Name:	RepRapFirmware for Duet 2 WiFi/Ethernet
                                              Firmware Electronics:	Duet WiFi 1.02 or later
                                              Firmware Version:	2.01beta1(RTOS) (2018-06-23b1)
                                              WiFi Server Version:	1.21
                                              Web Interface Version:	1.21.2-b1
                                              @chrishamm Just got the following error while trying to enter a new temperature at
                                              Settings -> List Items -> Add new Temperature:
                                              A JavaScript error has occurred so the web interface has closed the connection to your board. It is recommended to reload the web interface now. If this happens again, please contact the author and share this error message:
                                              Version: 1.21.2-b1
                                              Message: Uncaught TypeError: Cannot read property 'trim' of undefined
                                              URL: http://duet.localhost:8080/js/dwc.js
                                              Line: 7665:69
                                              Error object: {}
                                              Also found a typo in title text of
                                              Settings -> User Interface -> Machine Control -> Allow moves if axes are not homed
                                              where there is an "o" missing in "not" near the end of the text
                                              • wilriker
                                                wilriker Moderator @chrishamm last edited by wilriker
                                                As mentioned before I really like this feature. I just tried it with a M291 pop-up (as it would be used for e.g. manual mesh bed leveling) and it also works there but only partially. It will create the dialog to enter the new value but it will be hidden behind the M291 dialog which is modal and over everything else.
                                                EDIT: Now I just tried to change the value after clicking OK on the M291 dialog (which leaves the change-value-dialog open and it gets accessible that way) but when I click on OK then I get
                                                Version: 1.21.2-b1
                                                Message: Uncaught TypeError: Cannot set property '0' of undefined
                                                Line: 6419:64
                                                Error object: {}
                                                This might be due to the fact that the control that should be adjusted is already closed at that point.
                                                Sadly this is the very point where I would need this functionality. ๐Ÿ˜ž
                                                EDIT 2: Played a little more with it. I made the change dialog accessible (by juggling around in the order of the source code and setting top: 250px for this dialog in Chrome Dev Tools) and it still will fail due to the fact that stepChangeAxisIndex is -1 in this case.
                                                JoergS5 1 Reply Last reply Reply Quote 0
                                                • Catalin_RO
                                                  Catalin_RO @chrishamm last edited by
                                                  Could we also have more move steps buttons in a future version?
                                                  • Ethelred
                                                    Ethelred last edited by
                                                    +1 for more move steps buttons.
                                                    • chrishamm
                                                      TBH I never intended to make the move buttons configurable on the M291 dialog so this was in fact a bug which has been resolved in my current beta 2. This version is now available here: https://github.com/chrishamm/DuetWebControl/blob/dev/DuetWebControl-1.21.2-b2.zip Here the changelog once more:
                                                      • Custom themes can be used by uploading own .theme.css files
                                                      • Compensation type is shown in the Auto Calibration dropdown menu
                                                      • Fan and heater names can be assigned (see M305 S and M106 C parameters)
                                                      • Use "axes" value instead of "xyz" length to get number of configured axes
                                                      • DWC reloads itself/its settings when it/its settings are updated
                                                      • Implemented possibility to download the G-code log as a CSV or TXT file
                                                      • Webcam image can be flipped and rotated on demand
                                                      • Improved settings behavior when running on localhost
                                                      • Minor other changes
                                                      • Bug fix: Tool Fan was always updated even if the user tried to change its value
                                                      • Bug fix: Sometimes codes could be accidentally sent twice when the auto-completion was open
                                                      • Bug fix: Successful G-codes were added to the list of auto-complete items even if they had been sent from a button
                                                      • Bug fix: G1 S2 moves were incorrectly generated for jog movements on Delta and SCARA configurations
                                                      • Bug fix: Movement steps could be changed on modal dialogs
                                                      Be aware that you will need another firmware build in order to be able to rename your non-virtual heaters and fans. You can get my latest firmware build here: https://www.dropbox.com/s/kbjp5pp3wowwhot/Duet2CombinedFirmware.bin?dl=0 The corresponding sources can be found on the v2-chrishamm branch of dc42's firmware repository.
                                                      Please let me know if you encounter any problems or if everything is working well!
                                                      wilriker Phaedrux 3 Replies Last reply Reply Quote 1
