    Timelapse pictures & videos with Duet and webcam on layer change
    43
    7.5k
    • resamundefined
      resam
      Hi all,
      I wrote a little tool that allows me to create timelapse videos with pictures on every layer change, using a Duet controller, a Telnet connection from a Raspberry Pi (or other PC), and a webcam (to get still pictures over a URL):
      https://github.com/kriechi/DuetRRF-timelapse
      (see the README for more information)
      Feel free to ask questions or post feature requests!
      I hope somebody finds it useful!
      T3P3Tonyundefined 1 Reply Last reply Reply Quote 10
      • T3P3Tonyundefined
        T3P3Tony administrators @resam
        @resam awesome!
        www.duet3d.com
          This is great. Can't wait to give it a try. I miss timelapses.
          • Danalundefined
            Danal
            Fantastic.
            Now, we need to integrate this with the other "Proxy/Camera" Pi work that is going on, and produce a pre-built image.
            Phaedruxundefined 1 Reply Last reply Reply Quote 1
            • resamundefined
              resam
              If there is enough interest, I can make it a pip package, so it is easier to install and update. For now it still requires some manual setup and configuration.
                Phaedrux Moderator @Danal
                @danal said in Timelapse pictures & videos with Duet and webcam on layer change:
                Fantastic.
                My thoughts exactly.
                • Railgunner13fundefined
                  Railgunner13f
                  What is a good way to set up a USB webcam to return snapshot pictures (still image) via an URL? I tried this link and it seemed to install fine. But I'm not getting an image with http://127.0.0.1:8080/?action=snapshot in the raspberry browser.
                  • resamundefined
                    resam
                    I'm also using mjpg-streamer - there should be a bunch of different guides and how-tos out there, even specific ones for Raspberry Pi or other Linux devices.
                    @Railgunner13f the link you posted does not configure it as HTTP webcam, but uses port 9000 for streaming with a different protocol. Try this instead: https://github.com/cncjs/cncjs/wiki/Setup-Guide:-Raspberry-Pi-|-MJPEG-Streamer-Install-&-Setup-&-FFMpeg-Recording (only the top part).
                      Railgunner13f
                      Bingo!
                      I am finally capturing the stills!
                      Where do I send the beer!
                        Would you be able to post an example timelapse?
                        • resamundefined
                          resam
                          https://www.dropbox.com/s/2ti52rimgepaq7e/2018-07-01-eggs-abs.mp4?dl=0
                          and
                          https://www.dropbox.com/s/z4az144426w9icp/2018-04-05-Einstein-bust.mp4?dl=0
                            That's great. Exactly what I was hoping for. Hopefully I can find some time to get it setup soon.
                            • resamundefined
                              resam
                              @Phaedrux let me know how the mjpg-streamer stuff works for you. I'm thinking about removing this dependency and implementing a simple frame-grabber with OpenCV in Python directly... This means the webcam can't be used for Octoprint or other tools easily, but if people only want timelapses, thats fine.
                              Phaedruxundefined Danalundefined 2 Replies Last reply Reply Quote 1
                                Phaedrux Moderator @resam
                                @resam Will do. I'm thinking I will pick up another RPi3 to run this on. Or do you think a RPiZeroW with camera module would be good enough? I currently use MotionOS on the zero to act as an IP cam.
                                • resamundefined
                                  resam
                                  I'm running this on a RPiZeroW - good enough for 15fps streaming of 1280x720p and the snapshots with my script.
                                  • Danalundefined
                                    Danal @resam
                                    @resam said in Timelapse pictures & videos with Duet and webcam on layer change:
                                    Would this affect the ability to have the camera visible and updating in Duet Web Control?
                                    • resamundefined
                                      resam
                                      @Danal yes - in that case the "access to the webcam" is exclusive. Either timelapse snapshots or DWC/Octoprint/some other streaming.
                                      There might be a way around it, but it involves a more complex Linux setup - which I want to avoid. I can make it optional: "quickstart = exclusive timelapse snapshot" and as second option, the existing mjpg-streamer integration via a URL.
                                      Let me know how many of you want to keep DWC/Octoprint webcam access, and how many ONLY want to use timelapse snapshots.
                                      • T3P3Tonyundefined
                                        @resam would it be possible to serve those timelapse shots (or rather the latest one) to DWC? For remote monitoring it gives a once per layer update.
                                        www.duet3d.com
                                        • resamundefined
                                          resam
                                          @T3P3Tony probably - but the idea behind using OpenCV and ditching mjpg-streamer was to REDUCE complexity 😄
                                          For people who want to keep their DWC webcam, you should probably still use mjpg-streamer (unless somebody knows of a similar / better tool?)
                                          T3P3Tonyundefined assasinscreed00undefined 2 Replies Last reply Reply Quote 0
                                          • Danalundefined
                                            Danal
                                            Having a camera visible in DWC allows a human to periodically check from their mobile and abort prints that go wrong. And/or have the confidence at hour X that a long print is going right!! They may be checking from the next room, or across town. Timelapse is nifty to document, share, show to non-3D print people, etc. It is most desirable to capture these on the same long prints where remote monitoring is most desirable.
                                            Longwinded way of saying: If we are building an Rpi setup (or image) to provide a camera for Duet/RepRap based printers, it really should do both camera functions, seamlessly.
                                            Blending that with the desirability of a proxy function, the DWC camera view should work on "local network" or "via proxy" equally seamlessly.
