    Problem printing circles
    69
    5406
    • OBELIKS
      OBELIKS last edited by
      I have a problem I have not noticed before. It was always present, but I did not print circles except for the M3 holes. So I did not notice.
      Anyway, if it not seen from the video, on the big circle printer keeps speeding and slowing. It is choppy.
      And the weird thing is, there is a pattern in the circles. I get 3, 4, 5, 2, 5, 4 lines.
      My config is here (fresh), I also attached the gcode file
      Here is a octagon, so I could test straight lines, as you can see it works perfectly. Ignore the ugly print.
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.01beta2(RTOS) running on Duet WiFi 1.02 or later
      Board ID: 08DGM-956GU-DJMSN-6J9F4-3SD6M-1VR3G
      Used output buffers: 3 of 20 (16 max)
      Static ram: 28484
      Dynamic ram: 96032 of which 0 recycled
      Exception stack ram used: 420
      Never used ram: 6136
      Tasks: NETWORK(ready,328) HEAT(blocked,1248) MAIN(running,3616)
      Owned mutexes:
      Last reset 00:41:35 ago, cause: software
      Last software reset at 2018-07-16 21:09, reason: User, spinning module GCodes, available RAM 6208 bytes (slot 1)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      MCU temperature: min 42.9, current 43.2, max 44.2
      Supply voltage: min 12.4, current 12.6, max 12.8, under voltage events: 0, over voltage events: 0
      Driver 0: standstill, SG min/max 0/383
      Driver 1: standstill, SG min/max 0/458
      Driver 2: standstill, SG min/max 0/652
      Driver 3: standstill, SG min/max 0/524
      Date/time: 2018-07-16 21:51:26
      Slowest loop: 101.17ms; fastest: 0.08ms
      Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 150, MaxWait: 0ms, Underruns: 695, 1
      Scheduled moves: 0, completed moves: 0
      Bed compensation in use: none
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.5
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 172.91ms; fastest: 0.08ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is running
      WiFi firmware version 1.21
      WiFi MAC address 5c:cf:7f:76:5f:98
      WiFi Vcc 3.33, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 15296
      WiFi IP address 192.168.1.119
      WiFi signal strength -38dBm, reconnections 0, sleep mode modem
      === Expansion ===
      Test gcode: https://www.dropbox.com/s/hfvgd5zj1sb30em/Cylinder test.gcode?dl=0
      Stl: https://www.dropbox.com/s/hkadyoitr26z2r4/Cylinder test.stl?dl=0
      Video: https://photos.app.goo.gl/1CxSx4eu7rzz3dxa8
      0_1531770199343_config.g
      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
      Original Prusa i3 MK3S
        I have noticed similar surface quality on circles and smooth arcs but don't get the same exaggerated pause behaviour as seen in your video. I'll try printing your STL and see if I can duplicate it.
        Can you post your config.g?
        Are you using pressure advance?
        • OBELIKS
          OBELIKS last edited by OBELIKS
          Config.g is in the end of the post.
          No pressure advance, I was trying it, but I didn't manage to dial it in.
          The worst was on the big circle. And stl was prepared for 0,4mm nozzle, walls are 0,45mm thick.
          I just realized, I gave too little information. Printer is cartestian with steel frame, motors are supposed to be these: https://3dprint.wiki/reprap/anet/a8/steppermotor and the board is version 1.03
          And I put the octagon and square in so I could see if I have the same problems on them, I guess that would mean that it's not a problem with the board.
          • T3P3Tony
            T3P3Tony administrators @Phaedrux last edited by T3P3Tony
            @phaedrux I also checked the pressure advance @OBELIKS posted his config at the bottom of his post, no pressure advance enabled (thought thar as well after @deckingman's experiences
            www.duet3d.com
            • OBELIKS
              Just a quick thought, is there any buffers or cache that can be flushed?
              • 3DOeste
                3DOeste last edited by
                I once had a similar problem with another board and it was too little jerk. The circles came out exactly like yours. I’m not surr it’s the same problem, but increasing the jerk value solve the issue.
                • T3P3Tony
                  T3P3Tony administrators @OBELIKS last edited by
                  @obeliks there is a print buffer of moves during printing as the firmware needs to know what the next move is. That made me think about if the issue is related to having very many very short moves. so i looked at the gcode. There are loads of sections like this:
                  G1 X159.018 Y101.352 E0.16013
                  G1 X159.019 Y101.357 E0.00036
                  G1 X159.020 Y101.362 E0.00036
                  G1 X159.348 Y103.498 E0.16013
                  G1 X159.349 Y103.503 E0.00036
                  G1 X159.350 Y103.508 E0.00036
                  G1 X159.528 Y105.136 E0.12129
                  G1 X159.585 Y105.657 E0.03882
                  G1 X159.586 Y105.662 E0.00036
                  G1 X159.586 Y105.667 E0.00036
                  G1 X159.727 Y107.824 E0.16012
                  G1 X159.728 Y107.829 E0.00036
                  G1 X159.728 Y107.834 E0.00036
                  G1 X159.775 Y109.995 E0.16012
                  G1 X159.775 Y110.000 E0.00036
                  G1 X159.775 Y110.005 E0.00036
                  G1 X159.728 Y112.166 E0.16012
                  G1 X159.728 Y112.171 E0.00036
                  G1 X159.727 Y112.176 E0.00036
                  G1 X159.620 Y113.805 E0.12092
                  quite small moves
                  Can you try using another Slicer as a test to see what difference it makes? I note this is Slic3r Prusa edition version 1.40.1, so maybe try Cura to see the difference?
                  @deckingman I know there is no pressure advance involved but is this related to the issues you are seeing?
                  www.duet3d.com
                  OBELIKS deckingman burtoogle 3 Replies Last reply Reply Quote 0
                    Phaedrux Moderator @OBELIKS last edited by
                    @obeliks Sorry about that, I think the string of numbers made me glaze over that link.
                    • 3DOeste
                      I just looked at your config.g and I don’t think low jerk values are your problem. I think I’m using the same values...
                        I assume you are printing from SD card. The usual reason for this type of issue is that the XY jerk is set too low for the print speed.
                        OBELIKS 1 Reply Last reply Reply Quote 1
                        • OBELIKS
                          OBELIKS @T3P3Tony last edited by
                          @t3p3tony I will try Cura tomorrow. I don't like setting it up, but I will try. But I know that S3D gives more or less the same results. It's a bit annoying, that the old Anet board gave me no problems like that. But I hope we can get this sorted out.
                          • T3P3Tony
                            @obeliks try @dc42 and @3DOeste 's suggestions of increasing Jerk first.
                            www.duet3d.com
                            • OBELIKS
                              OBELIKS @dc42 last edited by OBELIKS
                              @dc42 I actually went from 20mm/s to 15mm/s just to check. It is also true that it was even worse with my old configuration (I havent stored it. I will check, but I think it is gone). Then the circles were flat on top and bottom.
                              What jerk setting would you suggest?
                                dc42 administrators @OBELIKS last edited by
                                @obeliks said in Problem printing circles:
                                The default value of 600mm/min works well for many users, but some users increase it to 900 or even higher.
                                Catalin_RO 1 Reply Last reply Reply Quote 0
                                • OBELIKS
                                  I have them at 900 st the moment. I will make a test tomorrow with 1200 and 600, so we can see the difference. And with Cura.
                                  • deckingman
                                    deckingman @T3P3Tony last edited by
                                    @t3p3tony said in Problem printing circles:
                                    quite small moves
                                    There are certain similarities for sure - although I only see it with pressure advance enabled. I've discovered that increasing extruder micro-stepping to 256x from 16x is a work around for my issue, so it would be interesting to know if doing the same has any effect on the OP's problem.
                                    • OBELIKS
                                      That is another thing that I have problems with. If I try to give command "M350 X256 Y256 Z256 E256 I0" I get something like "Drive E0 does not support 256 microstepping"
                                      I will try this and the rest when I get home from work.
                                      • deckingman
                                        deckingman @OBELIKS last edited by
                                        That's weird, but try this. Leave everything in your config.g as is but add M350 E256 at the end of your drive section (after the M84 command). This will mean that the steps per mm are first calculated using 16x microstepping, then when you add that line, the micro-stepping will be changed x 256 and the steps per mm for "E" will be automatically recalculated.
                                        You're not using external stepper drivers are you?
                                        OBELIKS 1 Reply Last reply Reply Quote 0
                                        • OBELIKS
                                          No.
                                          I will try this also. But this should work from gcode console also?
                                          • Catalin_RO
                                            Catalin_RO @dc42 last edited by Catalin_RO
                                            @dc42 RRF configurator default max jerk is 15mm/s, hence 900mm/min! Maybe 600mm/min is the default firmware value, but any config.g file generated with the configurator will have it overridden. I'm going to experiment a little bit with the idea, by increasing from the current 300mm/min in 50mm/min steps.
                                            • deckingman
                                              No.
                                              Yes
                                              • OBELIKS
                                                OBELIKS @deckingman last edited by
                                                @deckingman said in Problem printing circles:
                                                So first this one, as I said, if I put this in to G-Code Console, I get this error (bug?):
                                                M350 E256
                                                Error: M350: Drive E8 does not support 256x microstepping
                                                But it works if I put it in to config.g exactly as you suggested:
                                                M350
                                                Microstepping - X:16(on), Y:16(on), Z:16(on), E:256:256:16:16:16:16:16:16:16
                                                The result was slightly better. But there were still audible judder.
                                                Setting them all to x256 also did not help more.
                                                Setting jerk to 1200 or even 1800 makes no real difference.
                                                I will test Cura later
                                                deckingman dc42 2 Replies Last reply Reply Quote 0
                                                • deckingman
                                                  M350 E256
                                                  M350
                                                  That error message does rather look a bit like a bug as you don't have a drive E8. Anyway, it doesn't seem to have resolved your problem but it was worth a try.
                                                  • DocTrucker
                                                    DocTrucker last edited by
                                                    Similar issue to something I experienced. Tested with and without pressure advance and as was and increased Jerk. Increased jerk smoothed things out, pressure advance had comparitively little effect.
                                                    https://forum.duet3d.com/topic/5834/core-xy-judder-slowdown-on-circle/18
                                                    Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
                                                    • OBELIKS
                                                      Before I waste any more of our time, is there any option to make a fresh start on the board?
                                                      Would the erase button do that?
                                                      JoergS5 1 Reply Last reply Reply Quote 0
