    Problem printing circles
    69
    7.9k
    • OBELIKSundefined
      OBELIKS
      Can you check both gcode files, and see how many lines you get for the second ;BEFORE LAYER CHANGE
      Because for me it doubled with thin walls disabled.
      P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
      Original Prusa i3 MK3S
        @phaedrux said in Problem printing circles:
        full gcode
        https://www.dropbox.com/s/ormosogim0yaeq2/sliced gcode.7z?dl=1
        They can be found here.
        • OBELIKSundefined
          OBELIKS
          Thanks. I'll check tomorrow.
          • OBELIKSundefined
            OBELIKS
            I will also try the solution from this thread: https://forum.duet3d.com/topic/6078/core-xy-movement-issues/57
            • OBELIKSundefined
              OBELIKS
              So in additon to the fix above I also erased firmware and uploaded 1.21 Nothing changed.
              Turning off thin wall detection in Slic3r did help with the juddering, but not completely.
              Cricles still have flatspots on top and bottom, and printer still sounds rough.
              So I need to find some time to wire the old board back in and test the steppers.
                Phaedrux Moderator @OBELIKS
                @obeliks In addition to turning off thin wall detection did you also change your extrusion width to 0.4?
                • OBELIKSundefined
                  OBELIKS
                  Yes, and it is a different model anyway. So that is not really needed.
                  • OBELIKSundefined
                    OBELIKS
                    OK, we can stop blaming DuetWifi. I took the time (and anger at some relatives) and I switched to the old board. The uneven circles are almost the same.
                    Left is DuetWifi and right is Anet board, same gcode
                    Now that I have the old board on, I will do another test with Cura and S3D. But that will wait for tomorrow.
                    • sigxcpuundefined
                      sigxcpu
                      That is backlash in Y axis (if this is the printing position). There is also a smaller backlash in X axis, too.
                      • OBELIKSundefined
                        OBELIKS
                        I hope this is true.
                        I really need to reduce weight of the bed assembly. I ordered PCB bed without ALU and thinner glass. That should save me around 500g, and if this goes well I will replace the bed frame for ALU also, at the moment I have inox. That would mean at least 200g.
                        • sigxcpuundefined
                          sigxcpu
                          Unless you have very shitty belts that strech like crazy, there is no reason for the weight of the moving things to generate backlash. I have it too in Y on my CoreXY, but I am sure it is not the axis weight which is pretty thin.
                          If you suspect the weight is an issue then you can play with motors currents and/or acceleration and see if there are any changes.
                          timcurtis67undefined 1 Reply Last reply Reply Quote 0
                          • timcurtis67undefined
                            timcurtis67 @sigxcpu
                            @sigxcpu said in Problem printing circles:
                            I agree with this. @deckingman probably has the heaviest print head axis combo of everyone on this forum and he doesn't complain about backlash.
                            Ian, do you want to comment about this?
                            • OBELIKSundefined
                              OBELIKS
                              My bed assembly is in the region of 1,5kg
                              • deckingmanundefined
                                deckingman @timcurtis67
                                @timcurtis67 said in Problem printing circles:
                                Not really 😉 ............................
                                But since you asked...... I have 4kg split between two gantries so roughly 2 kg per XY mechanism. "No name" 6mm GT2 belts. Max X axis speed 50,000, max Y axis speed 35,000, accel 1,000 for both, jerk 600 for both. I have experimented with high print speeds up to 300mm/sec and my default non-print move speed is 350mm/sec. No sign of backlash but everything is pretty rigid. It'll print OK at higher accelerations but with the mass being over a metre above the floor, the printer tends to start to rock about a bit at high speeds.
                                As an aside, I don't get ringing either - one advantage of high mass 😈
                                • OBELIKSundefined
                                  OBELIKS
                                  Hah, I have a i3 style printer. So it is moving a lot. 😁
                                  I will investigate the whole mechanics of X and Y, something is wrong there, that I am certain.
                                  Aaaand, he deleted the post 🙂
                                    deckingman @OBELIKS
                                    @obeliks said in Problem printing circles:
                                    Yes, I realised my mistake - hence I deleted the post. For some reason I thought yours was a CoreXY the same as mine.
                                    Edit. So in which case, you could well have backlash or movement issues in Y
                                      You could try reducing the accel and jerk for your Y axis. I think in your config you have X and Y the same. It's not uncommon to use different values for i3 style printers because of the bed weight.
                                      • OBELIKSundefined
                                        OBELIKS
                                        I was thinking, and in the end it is probably a problem with the sintered bushes that I use instead of bearings.
                                        0_1532070978745_6fdbd05c-2520-4f36-9a74-4659fe73c9a7-image.png Image by Toolson
                                        I made a stupid decision and lubricated them, and they still move, but the moves are "sticky". I will try to clean them, and maybe switch back to linear bearings. I just need to find good ones.
                                        Is this still the right category for this thread?
                                        • OBELIKSundefined
                                          OBELIKS
                                          I took X and Y axes apart, cleaned all the components, so now it is gliding as good as it can. Positive is that printer got quieter, negative is that the circles are still flat on top and bottom.
                                          I am slowly running out of ideas.
                                          The only part that I still need to investigate is the print head. But it is rigid as it ever was.
                                            deckingman @OBELIKS
                                            @obeliks Did you ever try lower acceleration for your Y axis as someone suggested? I note that the motor currents are set to 800mA so presumably the motors are rated at 1Amp? If your bed weight 1.5kg, the Y motor might be struggling so either try lower acceleration, increase the current if you can, or a bigger motor.
