    Hot end maximum wattage possible
    26
    4.3k
    • mendeleviumundefined
      mendelevium
      I have a printer we designed having two extruders, EACH have TWO heaters x 50 watts x 12V.
      therefore, each hotend has 12V x 100watts which equals to 8.33 Amps load.
      I am changing over from a ramps setup. I bought the DuetWifi v1.03 board. Will this handle this power or would I need to power these through a solid state relays?
      I do not know if I am right, but somewhere I saw that the maximum power that the board can take in each hotend terminal is 5 Amp.
      Could somebody clarify please. Thanks
      • DocTruckerundefined
        DocTrucker
        "A 2-pin 3.5mm terminal block is provided for connecting each of the two supported hot end heaters.
        The design is rated to 5A per extruder heater connection"
        https://duet3d.dozuki.com/Wiki/Connecting_extruder_heaters
        "From Version 1.04 onwards the Duet 2 is fitted with 3 blade fuses:
        • 1A for the VIN going to the fans
        • 7.5A for the VIN going to the heaters and stepper motors
        • 15A for the VIN going to the Bed heater."
        https://duet3d.dozuki.com/Wiki/Hardware_Overview
        MOSFETS/SSR will be the way to go. With that sort of heating capacity read up on heater fault detection. Incorporating a mechanical relay controlled by PS_ON to kill the feed to the heaters (not fans) would be wise.
          DocTrucker
          Rebuilding the machine for 24V would half your current requirements and reduce the thickness of wire needed.
          The on board mosfets would cope, but you would blow the fuse. Feeding the heaters externally and usung the switched ground on the board would work.
          Would still be wise to use a relay to break the feed to the high side of the heaters.
          dc42undefined mendeleviumundefined 2 Replies Last reply Reply Quote 0
            dc42 administrators @DocTrucker
            @doctrucker said in HOT END MAXIMUM WATTAGE POSSIBLE:
            That is my recommendation too.
            Do the heaters need to be as much as 50W each?
            The mosfets and terminal blocks can pass well over 5A safely, probably 10A. It's probably safe to increase the fuse rating on the 1.04 board to 10A but I wouldn't go any higher than that.
              mendelevium
              Thanks Guys,
              that is what I principled in mind, but sharing ideas and getting people to say what they think is key to avoiding a trap. I tried using larger nozzles and found that my heater was unable to cope and if you go for materials requiring higher temperatures in my opinion would be necessary- I think. If the printer runs fast, it would need to melt instantly.
              correct me if I am wrong.
                mendelevium @DocTrucker
                @doctrucker I think I will go that way. In fact, having a large heatbed, I had to arrange a 24V Ac 400KVA transformer with a solid state relay already.
                • deckingmanundefined
                  deckingman
                  From the work that I've done with large diameter nozzles, a bigger heater doesn't help. There is no getting away from the fact that it takes time for the heat to find it's way from the outside surface of the filament through to the core, especially as filament itself is y poor conducter. I played around with an 80 watt heater which didn't help with the melt rate but was a complete PITA to control.
                    dc42 administrators @mendelevium
                    @mendelevium said in Hot end maximum wattage possible:
                    The other option is an AC mains voltage bed heater, with appropriate safety precautions. See https://duet3d.dozuki.com/Wiki/Choosing_a_bed_heater#Section_Bed_heater_driven_using_a_Solid_State_Relay.
                    True; but if you can solve the problem if getting the heat into the filament (e.g. by using a longer melt zone) , then you do need more heating power. At least, this is what E3D told me was limiting their prototype Super Volcano hot end (i.e. insufficient heating power to maintain temperature at high extrusion rates).
                      deckingman @dc42
                      @dc42 said in Hot end maximum wattage possible:
                      I solved the issue of getting heat into the filament by using multiple melt chambers radially located around a central heater cartridge. Managed to get up to 300mm/sec with a 0.5mm nozzle and 0.3mm layer height before running into problems. But there was no drop in temperature and that was with a 40Watt heater https://somei3deas.wordpress.com/2017/06/22/exploration-of-print-speeds-with-a-diamond-hot-end/
                      That was with 3 melt chambers. The 5 colour (melt chambers) is on my list of things to test along with larger nozzles.
                      When i tried an 80Watt cartridge, the only way I could control the wild temperature swings was to reduce the PWM to 50%, effectively reducing the heater output to 40 Watt.
                        mendelevium
                        Basically, i have designed a heatblock which consists of two cartridge heaters adjcent to the nozzle. It is in aluminium and very efficient. I intend to either produce it in brass or better still in copper. I have not yet tested the printer`s extruder capability to melt material fast. I believe that the heating must provide enough energy to fuse enough plastic otherwise speed serves no purpose. Secondly my idea is to strenghten the extruding capability by a geared arrangement with metal gears. I do not like extruder motors mounted on carriages for the inertia they cause during movement, so it will be bowden controlled. Eagerly waiting for my duet wifi to turn up and try it out...
                        • dragonnundefined
                          dragonn
                          Hmmm if you have Two 12V heaters you can put them in series and power from 24V, this would 'reduce' the current going through Duet.
                          mendeleviumundefined 1 Reply Last reply Reply Quote 0
                            mendelevium @dragonn
                            @dragonn would they provide the same power? I would think half as much power. Not a bad idea to run on 24v but i think that would halve the heating power...
                            dragonnundefined 1 Reply Last reply Reply Quote 0
                            • dragonnundefined
                              dragonn @mendelevium
                              @mendelevium No, when you run two 12V heaters in series from a 24V source the power will stay the same. Ohms law 😄
                                deckingman
                                ..........until one heater fails and you end up with 24v across a single 12v heater........
                                whosrdaddyundefined elmoretundefined 2 Replies Last reply Reply Quote 0
                                • whosrdaddyundefined
                                  whosrdaddy @deckingman
                                  @deckingman yep very bad idea...
                                  • elmoretundefined
                                    elmoret @deckingman
                                    @deckingman I guess you mean fails shorted? Haven't seen that. In that case, what happens when a single 12v heater on 12v 'fails'?
                                    If you have fusing in place to prevent a failed 12v heater on 12v from doing bad things, that same fusing would protect a 12v heater on 24v (as current would be doubled).
                                    And if you don't have the fusing, well, I'll take a 2x jump in current over a 10x jump in current.
                                    deckingmanundefined 1 Reply Last reply Reply Quote 1
                                      deckingman @elmoret
                                      @elmoret I wasn't thinking so much about blowing fuses, more about what happens when you suddenly lose half the resistance. The one remaining heater is going to get bloody hot I'd have thought, although in theory the PID should control it to some extent and prevent a fire - hopefully, maybe?
                                      • elmoretundefined
                                        elmoret
                                        @deckingman said in Hot end maximum wattage possible:
                                        How hot would a shorted single heater get? Especially when considering that not all heater shorts are guaranteed to blow a fuse or a trace on the PCB (could have a partially shorted heater resulting in say, half the normal resistance).
                                        I guess I just don't see how its any more dangerous than a single heater setup.
                                          DocTrucker
                                          Firstly, incase you are not aware fusing is to protect wiring, not devices. Typically you would calculate or measure expected draw, then find the next suitable fuse rating above this. Wiring is then sized so that the chosen fuse level is no more than 80% of the rated current of the wire. Further increases in wiring cross sectional area may be required to avoid unacceptable voltage drops. Where you have a more complicated system the wiring to the specific device maybe larger still, just to save the need for many different cross sectional area wires in different colours from the bill of materials.
                                          If a single heater fails short the current multiplies many times and will blow a fuse pretty quick as it blows to protect the wiring.
                                          The fail short of one 12V heater of two in series would cause the resistance to half, doubling the current. This will double the rated power of the heater and things will get smokey fast. Much like accidentally leaving a voltage select switch on a computer psu at 110vac...
                                          This would be difficult to protect against with fusing as a fuses are often only guaranteed to quick fail at double rated current. Time to fail increases as you reduce the current towards the fuses rated current, at which the time to fail is somewhere between anytime and never. Fusing is also only intended to protect the wire, not the device.
                                          Wiring would have to be sized to be safe for the expected current through one 12V heater when supplied with 24V, double the expected current through two 12V heaters in series.
                                          A current chopper style circuit could make it safer, as after all most of our stepper motors rated voltages are much below drive voltage.
                                          Easier to use a 24V heater! We're talking about less than a £10 here, how many hours work would it be to design and test a current chopper that never chops in normal use and then would need routine testing?
                                          • elmoretundefined
                                            elmoret
                                            This post is deleted!
                                            DocTruckerundefined 1 Reply Last reply Reply Quote 0
