    Very slow printing Duet Wifi on Am8
    995
    • ludodg
      ludodg last edited by
      Hi all.
      I wanted to reply on this topic:
      Re: (SOLVED) Duet Wifi slow printing
      .. but as it is very old, I might start a new one.
      Problem is as described in title:
      My AM8 prints fine quality but veeeeeery slow.
      A print that takes like 10h on my Prusa MK3 will take about 105 houres (!) on the AM8.
      I'm sure there must be a problem, something I missed but can't find it.
      As suggested in this other thread I altered the M201-settings, went from ecceleration-speed from 800 to 1200 ... but noticed no difference whatsoever.
      I'll try bump it some more but am afraid I'm lokking in the wrong direction.
      ANyone advice?
      My Config:
      ; generated by RepRapFirmware Configuration Tool on Thu Jun 21 2018 02:09:12 GMT+0200 (Midden-Europese zomertijd)
      ; adaptations by ldg - june,26 '18 - 21:30 a
      ; Custom code by ldg, thx JohnV 🙂
      M564 S0 H0 ; allow motormovement outside boundaries
      G21 ; work in millimeters
      ; M550 PDuettest ; Set machine name
      M550 PDuetLDG ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      ; DIRECTION
      ; M569 P0 S1 ; Drive 0 goes forwards
      M569 P0 S0 ; Drive 0 goes backwards
      ; M569 P1 S1 ; Drive 1 goes forwards
      ; M569 P3 S1 ; Drive 3 goes forwards
      ;STEPS
      ; M92 X80 Y80 Z4000 E420 ; Set steps per mm
      M92 X100 Y100 Z400 E101 ; Set steps per mm
      ; M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M203 X6000 Y6000 Z360 E1200 ; Set maximum speeds (mm/min)
      ; M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
      ; YET TOO SLOW M201 X800 Y800 Z15 E1000 ; Set accelerations (mm/s^2)
      M201 X1000 Y1000 Z200 E1000 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent -OK-
      M84 S30 ; Set idle timeout
      ; M208 X0 Y0 Z0 S1 ; Set axis minima
      ; M208 X220 Y220 Z240 S0 ; Set axis maxima
      M208 X-36 Y-5 Z0 S1 ; Set axis minima
      M208 X184 Y215 Z240 S0 ; Set axis maxima
      ; M574 X1 Y2 Z1 S0 ; Set active low endstops
      M574 X1 Y1 Z1 S0 ; Set active low endstops
      ; !! actually no probe yet ?!?
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
      M557 X15:205 Y15:205 S20 ; Define mesh grid
      ; ldg: No idea yet if these data are default and/or correct
      ; ADDED by ldg
      ; Configuring, finetuning heater-functions: detecting properties, PID-settings
      ;M307 H0 ;status Bed
      ;M307 H1 ;status Extruder-heater
      ;M303 H1 P0.6 S250 ;starts autotuning Extruder
      ;M500 ;saved data to memory/config
      ;M307 H1 ;report data: gain=A ConstantTemp=C DeadTime=D
      ;M307 H1 A337.7 C175.3 D8.3 ;line can be manually added to config but should be included in automatic added file config-override.g
      M307 H1 A337.7 C175.3 D8.3 B0
      M563 P0 D0 H1 ; Define tool 0
      ; Automatic power saving
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
      ; Custom settings are not configured**
      • ludodg
        This is a movie, made while it was simply printing a brim:
        https://www.youtube.com/watch?v=z62fujeEcYY
        • deckingman
          deckingman @ludodg last edited by
          @ludodg Nothing leaps out at me from your config.g (but I might have missed something). Looking at the video, it isn't acceleration that's the problem. Do normal moves through the web interface works at the correct speed? If so, then it has to something to do with the gcode file you are trying to print. What speed was it sliced at? Obvious question but what is the speed fact slider in DWC set to? Is there any sign of an M220 command anywhere? If you type M220 into DWC without any other parameters, what does it report?
            Do you happen to be using mesh grid compensation? Your Z jerk is quite low (only 0.2mm/s) and that could be limiting the speed of XY moves as it has to slowly adjust the height of Z. Try increasing it to 60 (1mm/s) and see if it improves.
            Can you run an M122 and post the results?
            deckingman 1 Reply Last reply Reply Quote 1
            • deckingman
              deckingman @Phaedrux last edited by
              @phaedrux Good catch (about the mesh compensation and slow Z speed).
              • ludodg
                Hello.
                Thx for looking into this with me.
                Mesh compensation? Again, some studying to do, I guess 🙂
                as requested:
                M122
                Used output buffers: 3 of 32 (6 max)
                RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
                Board ID: 08DGM-956GU-DJMSN-6J9F8-3S06S-KAQZG
                Static ram used: 16152
                Dynamic ram used: 100584
                Recycled dynamic ram: 2048
                Stack ram used: 1224 current, 6464 maximum
                Never used ram: 5824
                Last reset 01:18:40 ago, cause: reset button or watchdog
                Last software reset at 2018-07-28 00:05, reason: User, spinning module GCodes, available RAM 5672 bytes (slot 2)
                Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
                Error status: 0
                Free file entries: 9
                MCU temperature: min 40.0, current 45.5, max 45.8
                Supply voltage: min 12.0, current 12.5, max 12.8, under voltage events: 0, over voltage events: 0
                Driver 0: ok, SG min/max 0/616
                Driver 1: ok, SG min/max 0/487
                Driver 3: ok, SG min/max not available
                Slowest main loop (seconds): 0.042753; fastest: 0.000046
                MaxReps: 3, StepErrors: 0, LaErrors: 0, FreeDm: 174, MinFreeDm 150, MaxWait: 436051ms, Underruns: 0, 0
                Scheduled moves: 33946, completed moves: 33916
                Bed compensation in use: none
                Heater 0 is on, I-accum = 0.0
                Heater 1 is on, I-accum = 0.6
                Segments left: 1
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is doing "G0 X89.372 Y114.372" in state(s) 0
                serial is idle in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is running
                  WiFi firmware version 1.21RC4(08b3)
                  WiFi MAC address 60:01:94:73:5b:e0
                  WiFi Vcc 3.34, reset reason Turned on by main processor
                  WiFi flash size 4194304, free heap 15976
                  WiFi IP address 192.168.0.175
                  WiFi signal strength -62dBm, reconnections 0, sleep mode modem
                  Socket states: 2 0 0 0 0 0 0 0
                  === Expansion ===
                • ludodg
                  I guess I'm not running any grid compensation as I do not have a bed-level-sensor (yet)
                  Might be something with my slicer ... (Slic3r Prusa Edition). The probleem seems less when slicing with cura... But that would very weird.
                  • ludodg
                    @phaedrux said in Very slow printing Duet Wifi on Am8:
                    Can you explain to me where you read this value?
                    Do you mean Acceleration? So "M201 Z200"? Changing this to a higher value?
                    Or is it about M566?
                    Thx!
                    • deckingman
                      @ludodg said in Very slow printing Duet Wifi on Am8:
                      Not really. There are all sorts of speed settings in each slicer and each one will only do what you tell it to. Did you check to see if moves via the web console are at the correct speed? If so, then the problem is likely to be the speeds that were used to slice the model. In Slic3r, look in the "Print Settings" tab, then under "Speed". What are the various speeds set too?
                      ludodg 1 Reply Last reply Reply Quote 0
                      • deckingman
                        Thx!
                        He means instantaneous speed change. But as you aren't using any form of flatness compensation, the Z axis won't be moving so don't worry about - that's not the reason for your problem.
                          You could post a gcode file that has been sliced with Slic3r and we could see all of the settings slic3r has used since it saves a copy of all it's settings at the end of every file.
                          • ludodg
                            ludodg @deckingman last edited by
                            @deckingman
                            Indeed, moving via de webconsole seems to function ok. Homing is happening at normal speed.
                            Print Speed settings:
                            I'll check those, ... but it now uses the standard settings that came with the latest firm- and software :s
                            It has to be SlicerPE as the AM8 now prints Ok when using Cura for slicing.
                              Phaedrux Moderator @ludodg last edited by
                              @ludodg standard settings for which firmware and software?
