    Wiring Duex
    1234
    • Kskiff7034
      Kskiff7034 last edited by
      So I got my Duet Wifi all setup and pushing plastic at 3am last night. I was originally going to get a Duex, then decided against it, but while setting it up I remembered why I wanted one: auto bed compensation!
      So I just ordered one. I'm looking over the wiring info on the duet page and I'm a little confused. It says:
      "VIN and GND terminals of the Duex5 to the corresponding terminals of the Duet WiFi. "
      If I run the wires from the VIN and GND from the Duex to the Duet, how does the power supply connect?
      The wiring guide leaves a bit to be desired. I really just need to understand how to hook the power supply up and I'll be all set though. As always, any help is appreciated.
        Use the two-input ferrules we supply to connect two wires to one terminal: a long wire from the PSU, and a short wire to join the VIN terminals of the Duet and DueX.
        For the +ve connections, you can run separate wires from the PSU to the Duet and DueX if you prefer. But the negative wire between the Duet and DueX VIN terminals must be very short.
        • Kskiff7034
          Ah got it! Two more quick questions:
          1. I've been using 14awg wire for the PSU to the Duet. Do you suggest going thinner? I'm using a 24v PSU.
          2. Which board should get the two wires? The Duet or the Duex? Or does it not matter?
            dc42 administrators @Kskiff7034 last edited by
            1. Work out the maximum current and choose suitably-rated wire.
            2. The Duet normally takes more current because of the bed heater, so the wire from the PSU should go to the Duet first. 14awg is good if the ferrules can accommodate two of them.
            • Kskiff7034
              So the Duex didn't come with any additional twin ferrules, just single wire ones. The Duet Wifi came with two of them, but I already used them when I originally set up the duet. I tried taking them off and seeing if I could salvage them, but it's not going to work.
              I ordered a ferrule kit the other day and it should be here today or tomorrow. It's only single wire ferrules though. So I have two questions.
              A) Could I use a single wire ferrule and then attach a piggy back connector and have two wires going into it?
              or
              B) Could I use a larger gauge ferrule, say 10 or 12, and then a little electrical tape and heat shrink tubing?
                A. Yes if you can find a suitable piggy back connector.
                B. I'm not sure whether 10 or 12AWG ferrules will fit in the terminal block. I think 2.5mm^2 ferrules should fit but maybe not 4mm^2.
                • Kskiff7034
                  Okay awesome I've got plenty of piggy back connectors. Ferrule kit will be here tomorrow and I'll wire it up. Thanks again, man -- you're always so helpful.
                  • BlueDust
                    BlueDust last edited by
                    So, from what I gather, the negative terminals of the Duex and Duet2 boards are connected together with a very short (black) wire. The positive terminals could also be wired (red) the same way but could also each go back to the power supply.
                    The Duet2 board will have two wires (black) coming out of the negative terminal, one going to the Duex and one going to the power supply. Depending on your personal choice, the positive terminal could also have two wires (red) coming out, one to the power supply, and one to the Duex.
                    I have read the documentation a few times and still get confused when I read it again for confirmation.
                    Is there a wiring diagram (picture) out there of how to properly wire the power of a Duet2 and Duex5 together?
                    Thanks!
                    Fun, that 3 letter word with "u" in the middle.
                    dc42 T3P3Tony 2 Replies Last reply Reply Quote 0
                      dc42 administrators @BlueDust last edited by
                      @bluedust said in Wiring Duex:
                      All correct.
                      • T3P3Tony
                        T3P3Tony administrators @BlueDust last edited by
                        @bluedust Thanks for pointing out the documentation could be imporved. I have added a picture now which should make it clearer for others:
                        https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                        Duex Power Wiring
                        Duet Hardware Designer
                        www.duet3d.com
                        • BlueDust
                          BlueDust last edited by BlueDust
                          @dc42 @T3P3Tony
                          Thanks for the confirmation and updating the documentation. I am hoping to have a new duet case printed this weekend to hold both boards.
                          I already printed one in PETG but could hear static sparks as I pulled it off the glass. Now worried it would kill the boards. I will be printing new ones in PLA....
                          I just want to power it up and start playing!
                          Thanks again!
