    4 z axis 3D printer
    My Duet controlled machine
    2083
    • Marine85
      Marine85 last edited by
      I am using duetwifi with duex I am using 4 axis for z each motor connected to a driver.
      How to configure the 4 z axis to home on independent endstop to make sure that my gantry is not tilited as well i am using z probe for bed leveling.
      Thanks,
        Have you seen this?
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        Marine85 1 Reply Last reply Reply Quote 0
        • gtj0
          gtj0 last edited by
          And this...
          https://duet3d.dozuki.com/Guide/Independent+Z+motors+and+endstop+switches/18?lang=en
          • Marine85
            Marine85 @Phaedrux last edited by
            @phaedrux Ye I have seen this, but it is not clear how to use independent endstop with each z motor
            • Marine85
              Marine85 @gtj0 last edited by
              @gtj0 this looks what i am looking for ,I will have a look!
              Thanks!
                Unless you have a very large bed that is flexible enough to twist under the forces applied by the leadscrews, it is better to use just 3 motors to lift the Z axis. Three points define a plane, and a sufficiently rigid bed is a plane.
                • Marine85
                  Marine85 @dc42 last edited by
                  @dc42 Yes I have a large bed 1300 x1300 but I did stiffeners as support so I would say it is rigid enough for this size.
                  can i do the same you just said with 4 motors as I already did the mechanics and everything is great so far?
                  • gtj0
                    gtj0 last edited by
                    With the 4 screw setup it's the rigidity that's the issue. Let's say you have 4 motors at the 4 corners: X0 Y0, X1300 Y0, X1300 Y1300, and X0 Y1300. Now let's say the X0 Y0 motor moves its corner down but the others don't move at all. With a perfectly rigid bed, the line between the X1300 Y0 and X0 Y1300 corners are going to make a pivot point forcing the X1300 Y1300 corner UP. Something is going to break.
                    Could you can make the 2 "back" motors a virtual motor?
                    Maybe support the bed directly between them instead of at the corners then use the 2 Z motor connectors on the Duet to drive both motors together? Then you'd have a 3 point mount without having to actually move the motors or leadscrews.
                    • Marine85
                      @gtj0 Thanks! it is clear now
                      I think I have some flexibility on my bed and no issue with that.
                      I want to be able to home them to Z-MAX and sync the motors using limit-switches and use Bed levelling using multiple independent Z motors after that ?
                      • mrehorstdmd
                        mrehorstdmd last edited by mrehorstdmd
                        If you set up some hard stops at Zmax at each screw, that force the bed perpendicular to the Z axis, you can just run the bed slightly beyond Z max. The motors will stall when the bed hits the stops and that will force it into the level state and synchronize the motors - no switches needed. Prusa does this in the i3 printers to align the X axis perpendicular to the Z axis and synchronize the Z motors. It seems to work pretty well/reliably.
                        • Marine85
                          Marine85 @mrehorstdmd last edited by
                          @mrehorstdmd that is great
                          how can i configure this , or just i enable motor stall detect ?
                          Phaedrux mrehorstdmd 2 Replies Last reply Reply Quote 0
                            Phaedrux Moderator @Marine85 last edited by
                            @marine85 In your homing macro you can reduce the motor current at the start to make it easier for the motors to stall and then increase it again after.
                            • Marine85
                              @phaedrux many thanks , but is there more details to do this
                              I am beginner with G code☺
                                Well there were the two guides posted above. Did you read through those yet?
                                • Marine85
                                  @phaedrux Yes I did but nothing has been mentioned regarding Macros
                                    The homing files are macros. So is config.g really. A macro is a file containing a sequence of gcode commands.
                                    How far along are you in the commissioning of your printer? It may be best to start with a simple endstop for homing to ensure everything is working before moving on to a more complex arrangement like auto bed leveling.
                                    • mrehorstdmd
                                      mrehorstdmd @Marine85 last edited by
                                      @marine85 You really don't need stall detect. If the Z axis is 300 mm long, send the bed to Z=305. It's going to stall when it gets to Z=300 because you've set up physical stops that prevent it from going any further.
                                      Reducing the current when you get close to Z=300 is probably a good idea, especially if you have a lot of torque available in the Z axis.
