    Stall detection and use on a CoreXY
    • Zesty_Lykle
      Zesty_Lykle last edited by
      Hi all,
      After some reading, I am wondering if I should use stall detection for my homing process on the CoreXY I am designing.
      It needs to be a very accurate homing position, so is it the right choice? With enough tweaking can I get to a high degree of repeatability, or should I decide now to go for sensors instead?
      As I am still designing, I can probably find the space to place sensors. If I have to add them later, it might be more difficult.
      Lykle
      Design, make and enjoy life
      Co Creator of the Zesty Nimble
      • T3P3Tony
        No, stall detection is not accurate enough on its own see:
        https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Limitations_of_stall_detection
        microswitches as endstops are low cost, repeatable and easy to use!
        Duet Hardware Designer
        www.duet3d.com
        • Zesty_Lykle
          Thanks Tony,
          That is what I thought, just wanted a sanity check.
          Although in my case sanity is probably a wrong word.
          Lykle
