    PanelDuet chamber temperature?
    PanelDue
    1450
    • tech
      tech last edited by
      Hi, Is it possible to change to have the display of the chamber temperature?
      Thanks
      Chris
        It's on the wish list.
        • tech
          tech last edited by
          Do you know when this will be added?
          Thanks
          Chris
            I won't be working on PanelDue firmware until October at the earliest due to upcoming work on RepRapFirmware. It's quite a lot of work to display chamber temperature because PanelDue needs to fetch all the heater mappings just like DWC does, and work out how they are assigned to tools and bed and chamber heaters. I'll be changing the way heaters are displayed at the same time to allow for variable tool/heater mapping.
            tech sonderzug 2 Replies Last reply Reply Quote 1
            • tech
              tech last edited by
              Ok, thanks for the follow up!
              Best Regards
              Chris
              • tech
                tech @dc42 last edited by
                I follow up on the discussion we had about the chamber temperature. I was wondering if you started the working and when do you expect to see the new version?
                Thanks
                Best
                Chris
                • sonderzug
                  sonderzug @dc42 last edited by sonderzug
                  @dc42 I'd like to carefully resurrect this thread and inquire about the implementation of this feature. Not so much to nag but maybe to add to the list of people who requested it. Chamber temperature is an important metric with my high temperature printer (+150 °C chamber temperature), and using macros for this and running to the computer to check on the status of the heating process is quite a nuisance.
                  Best regards,
                  Niklas
                  • Kashyap
                    Kashyap last edited by
                    @dc42 I have heated chamber as well, it would be great if you could implement in future build.
                    Thanks and Best,
                    Kash
                      It's on my list for the next major version of PanelDueFirmware.
                      • stuartsm
                        stuartsm last edited by
                        Although I'm a bit late, I'm im the middle of implementing an enclosure and enclosure heater. I would love display and control of enclosure temperature from the front panel. Using the console to issue M141 commands works but is less than convenient.
                        • tojosaja
                          tojosaja last edited by
                          I got my paneldue 7i a few days before and I had to notice that the chamber temperature still can't be seen or adjusted. I reviewed the code and the implementation seems to be possible with manageable effort.
                          Is anybody still working on the implementation?
                          dc42 stated he will do so with the next major release. But it would be good to know when it will be published to decide whether to wait or to program by myself...
                          • taconite
                            taconite last edited by
                            +1
                            add me to the list of interested people
                            Custom ANET A8
                            Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                            All I do here is under this license: CC BY-NC-SA
