    Building dc42's Kossel?
    1356
    • 3dmntbighker
      3dmntbighker last edited by
      Who among us is building, has built, or plans to start building dc42's Kossel? I'm working my way through the BOM on aliexpress, etc. Already found some things that don't appear on the sites listed in the BOM. Like the corner extrusions are not on robotdigg.
      Scratch built CoreXY with Maestro
      Heavily modified Ender 3 with Maestro
      MPCNC work in progress with Duet WiFi
      JohnOCFII dc42 2 Replies Last reply Reply Quote 0
      • JohnOCFII
        JohnOCFII @3dmntbighker last edited by
        @3dmntbighker You might be interested in the kit from Think3DPrint3D: https://www.think3dprint3d.com/3D-Printer-Kits/complete-3D-printer-kits/Kossel-XLplus-3dPrinter-Kit
        3dmntbighker 2 Replies Last reply Reply Quote 0
        • 3dmntbighker
          3dmntbighker @JohnOCFII last edited by 3dmntbighker
          @johnocfii said in Building dc42's Kossel?:
          I'll give it some thought.
          edit: Actually, that kit is looking better and better. The shipper is DHL, and pretty affordable. They suck, but that's a good price. DHL is Fed-Ex Ground over here as far as I know. And Fed-Ex Ground is the worst. The only thing I immediately see that I would change is a magnetic PEI bed surface. But it's a VERY solid kit. Machined 2060 is a nice touch.
            dc42 administrators @3dmntbighker last edited by
            @3dmntbighker said in Building dc42's Kossel?:
            You mean the aluminium vertices? https://www.robotdigg.com/m/product/555/2040-or-3030-Alu-Vertex-for-Kossel-XXL-or-XXXL
            3dmntbighker 1 Reply Last reply Reply Quote 0
            • PlasticMetal
              PlasticMetal last edited by
              I'm currently building a new delta to replace my current SeeMeCNC Rostock v2, and am using David's blog as a guide. I have built it to the same size, but many of the items I sourced on my own. I'm in the US, and for example I used the RobotDigg corners, but got them as "scratch & dent" from Ultibots, and my extrusion is from OpenBuilds.
              • janjoh
                janjoh last edited by
                I built a delta that funnily enough turned out to be extremely similar to DC42's build. I actually didn't find his blog post until most stuff was ordered.
                Then again, if you have the mindset of "nothing weaker then 2040, no printed parts in the kinematics or frame, duet"... you kind of automatically end up with something very similar to DC42's build 😄
                • DADIY
                  DADIY last edited by
                  I built a DC42 Kossel, but one thing I could not source was the linear rail, I went taller (~1.8m) and although at the time I worked out my BOM when it came to ordering, RobotDigg cancelled my order and other sellers in Ali Express either said they had it and then didn't, or in one case agreed a discount for 3 lengths and then took the order and then wanted more money. They eventually refunded.
                  In the end I went with the think3d carriages and shaped wheels that run up the 2040 extrusions which so far i have been quite happy with, but ultimately I would like to get linear rails.
                  • 3dmntbighker
                    3dmntbighker @dc42 last edited by
                    @dc42 My bad, I mis-read the description when I saw 2020 x 6.
                    Thanks 🙂
                    • 3dmntbighker
                      3dmntbighker @PlasticMetal last edited by
                      @plasticmetal said in Building dc42's Kossel?:
                      Ultibots is out of scratch and dent, and their shipping is pretty high. So is Openbuilds for that matter 😞 But a LOT faster that aliexpress of course.
                      • 3dmntbighker
                        For the record in this thread these kits are currently NOT available. I contacted them, and he says he has too much on his plate related to Duet to fill any orders. Apparently a deal is pending to offload the work to someone else. But at the moment it's a dry hole.
                          It's worth asking them if they can supply partial mechanical kits, because I understand that they have some sets of linear rails, corners, extrusions etc. still.
                          • Barracuda72
                            Barracuda72 last edited by
                            beside....1350€ is alot...have a similar build and all together its about 700-800€
                            Corner
                            Rails
                            Extrusions from Motedis
                            Smart effecor...duet Wifi..
                            Stepper from stepperonline
                            ok..many of the small parts like srews etc i had already at home. Beside its quite nice to improve the design...for example build it upside down with steppers on top so you can build it with a smaller footprint
                            • 3dmntbighker
                              @dc42 said in Building dc42's Kossel?:
                              That's exactly what I asked him as a matter of fact, and the answer was no.
                              • 3dmntbighker
                                3dmntbighker @Barracuda72 last edited by
                                @barracuda72 said in Building dc42's Kossel?:
                                Corner
                                Rails
                                I would be surprised if you can can reproduce that build kit for that price. One major advantage of the kit is a custom wire harness with actual copper wire. Chinese parts come with cheap wire that has caused me all sorts of issues. It's a very well thought out BOM. If you compromise quality though I'm sure you can reduce the cost greatly. Always the balancing act.
