    Piezo20 probe and piezo kit now available
    423
    98.9k
    • DjDemonDundefined
      DjDemonD
      If it's one that I made the disc fitted when I made and tested it. But sure you can print a new one if you want. Might be worth watching my YouTube video series on assembling it. It looks simple but won't work if done wrong.
      How to Guides: https://www.youtube.com/playlist?list=PL9g_2J-RjkRCy5Sr5gIVwMYGhI9DrJewq
      Sorry for being a while getting back to you I don't check here so often our official support thread is at reprap forum:
      http://forums.reprap.org/read.php?1,767998,page=13
      www.precisionpiezo.co.uk
      • fmaundefined
        fma
        Hi!
        As cheap piezo discs are mostly made to build buzzers, why not using them this way?
        The idea is to use 2 piezos: one on the head, and one somewhere on the heatbed. One of them is used to generate a vibration, and the other one to detect this vibration, which will be transmitted when the hotend is in contact with the bed.
        It should be possible to find a resonant frequency to optimize transmission (far from motor vibrations and other noise…).
        In fact, any kind of transducer can be used on the bed, to generate the frequency, to have more power than a simple piezo, so it can be easily detect by the head.
        A friend in our hackerspace wrote, a few months ago, an Arduino routine to detect a single frequency, which can help to analyse the signal: https://gist.github.com/edgar-bonet/0b03735d70366bc05fc6
        Just an idea. Let me know if it has already been discussed.
        Frédéric
        • DjDemonDundefined
          DjDemonD
          Thanks, it has been discussed more so on reprap in the general piezo thread http://forums.reprap.org/read.php?1,635075. I've never tried it, but whilst its an alternative approach is it potentially a solution looking for a problem, as the current method works so well adding a second piezo, and possibly adjusting/changing the PCB to search for the frequency outputted by it, would only be worthwhile if we were going to gain some sensitivity or better discrimination between a trigger and a false trigger (with current firmware settings this isn't particularly a big problem). I'm down to 4g of force to trigger on my microdelta with underbed piezos.
          • fmaundefined
            fma
            Well, I was trying to find a solution which doesn't need specific mount for the hotend nor the bed…
            I will read the reprap thread. Thanks.
            Frédéric
            • DjDemonDundefined
              DjDemonD
              The gold standard (unless you want to calibrate/level manually) is electrical contact, but we don't have conductive printing surfaces, on the whole, so it isn't practical. You can get conductive PEI at eye-watering prices.
              • Whitewolfundefined
                Whitewolf
                @DjDemonD:
                It was how it arrived look at the photo, bought one of your drop in units. I only dissasembled to see why it was so lop sided (have not even installed the thing because i dont want a hotend that sits at an angle. the disc does not fit in the outer recess, i will print another and follow the video. or i might just wait and install the bed sensors that you are shipping to me
                just giving you a heads up for QA
                Exploring the universe wherever the tech blows
                • DjDemonDundefined
                  DjDemonD
                  That's just very odd, is it installed already? I'm tempted to send you another one and pay you the shipping to return it by regular airmail. I'd like to see what happened.
                  If it's installed and working then leave it if you're happy to.
                    Whitewolf
                    Its not installed, it arrived, i took it out of the package made my post here then left on a fishing trip. Came home to an overheated and fried computer from this heatwave we are having 😞 hopefully ill have my computer up and running by the time your bed piezo sensors arrive.
                    • fmaundefined
                      fma
                      Does anyone has a working design for a Diamond hotend? Ian, did you make progress on yours?
                      Frédéric
                      • DjDemonDundefined
                        DjDemonD
                        Your best bet here, and quite practical on a delta, for example, is to use underbed piezo sensors. There are designs for mounts, and with a stationary bed it works very well.
                        Here are some exmaple bed mounts
                        https://www.thingiverse.com/thing:2446460
                        You add to that the piezo kit:
                        https://www.precisionpiezo.co.uk/product-page/precision-piezo-z-probe-kit
                        After a bit of tuning you should be probing away with high sensitivity and with whatever hotend/nozzle you want.
                        • fmaundefined
                          fma
                          Ok, thanks.
                          Frédéric
                          • fmaundefined
                            fma
                            Mmm, I may have another idea… What about having the hotend (any hotend, in fact) mounted on a support which is anchored on one side, but free on the other side. On this free side, it is supported on a piezo disc. In order to have a good sensitivity, a spring put the right force on the piezo (just to maintain the head in its position). Then, once the bed calibration is done, an additional force can be applied (to increase the spring one) to firmly maintain the hotend (it can be a simple servo eccentric)...
                            In fact, it can be the opposite: a very strong spring firmly maintains the hotend, and the servo releases a little bit the force so the piezo is less strained, and more sensitive. Could work with a FSR too.
                            Frédéric
                            • franzelkaundefined
                              franzelka
                              I ordered an assembled kit (screwmount version) and I‘m very curious how it will perform compared to the IR sensor (tilt problems etc.)
                              I didn’t find a dedicated effector design for my Kossel Mini (Think3DPrint3D). What will be the best way to mount the piezo20, just screw underneath the original effector?
                              • DjDemonDundefined
                                DjDemonD
                                Thanks for the order.
                                Compared to the IR sensor (unless you have an evenly reflective (to IR) bed surface, which remains evenly reflective at all times, and no tilt), it will be like breathing fresh air. Tilt isn't a problem in the same way. There is no x or y offset so the nozzle determines the height at any given probing point, whether the entire effector and attached nozzle are tilted or not. In theory, if your tilt is quite minimal this should generate little/no issue with calibration/first layer thickness.
                                However, if you have a very precise machine (or large one) then tilt is still going to feed into your calibration and reduce its accuracy to some extent, as instead of the trigger height being different relative to the nozzle at different probing points because of tilting that you see when using an offset sensor, its the nozzle height that changes if the effector tilts. So try to get rid of tilt if you can.
                                As for mounting start off by using the supplied drilling guide (also a natty keyfob) to drill 2 3mm (3.5mm) holes equidistant from your central hole for your filament path, then screw the unit under your effector using m3 screws. This works but absorbs around 18mm of your z printing height.
                                Once you've determined you are satisfied with the performance of it, consider designing an effector with the upper part of the unit integrated into it (even better if this is raised above the effector, so that just your heater block hangs beneath, this really reduces the effect of any tilt you might still have, but makes cooling the heatsink a little more challenging), to regain the z height you lost.
                                • zendesignerundefined
                                  zendesigner
                                  HI Simon,
                                  I just ordered your Orion module yesterday , with the intention to use it with a duet Wifi on a Kossel Metal delta printer.
                                  Nice to find your thread here. looking forward to reading it and combining it with the DUet.
                                  Bart
                                  • DjDemonDundefined
                                    DjDemonD
                                    Thanks Bart. I think it will provide a great addition to your printer and its duet board. Accurate probes on a delta reduce the workload considerably.
                                    • deckingmanundefined
                                      deckingman
                                      @fma:
                                      No. I went for a different arrangement. My Diamond hot end assemblies (3 of them) have steel dowel pins which mate with oil filled bronze bushes in the X carriage. This allows an amount of Z movement whilst constraining any XY movement. Actually I reamed out one of the bushes and use a couple of springs on the other bushes which allows the hot end assembly to tilt when pushed from below. Then I went for a simple precision switch which has a repeatability of 0.005mm. So basically the hot end is the probe like the Piezo but I'm using a simple switch instead. When the nozzle comes into contact with the bed, the side of the assembly nearest the switch tilts upwards. I've got it set so that it only takes 0.3mm of movement to trigger the switch. It works like a charm and has been running for about a year. The mechanics are a bit involved but there is no calibrating - it's just a simple (but quite expensive) switch.
                                      I wrote a bit about it on my blog, about half way down this page https://somei3deas.wordpress.com/my-corexy-printer-build/
                                      There is a bit more on this YouTube video https://www.youtube.com/watch?v=0lW0EgNX0iQ&t=50s from about 2:24 and again at 3:42.
                                        zendesigner
                                        HI Simon or maybe DC42 😉
                                        I'm currently testing the orion module you send me on my Duet wifi. Duet is configured with wifi and i'm testing the zprobe and end stops to see if it works.
                                        So now i have this upside down behaviour.
                                        • The orion reacts to taps and switches from a red led to the blue one. I calibrated the sensitivity and thats ok. Now when i just push on my hotend it only triggers when i release it. I looked at your tuning video and you mention if this happens that you have soldered the piezo wrong. so don't think this is the case here as i installed exactly the same as your latest video.
                                        • Now in the webinterface of duet the Z probe is seen + the voltage is ok. But it stands constanly at a value 667 and when i tap the orion it returns quickly to zero.
                                        *reversing the connector on orion makes the red led on all the time and creates the correct behaviour that it triggers on push down. But that then put's the value on 880+ in the duet and it almost doesn't change when tapped.
                                        So what am i doing wrong and what needs to be reversed somewhere to get the correct 0 - 600+ value when triggered in dueton push down of the nozzle, not on release?
                                        these are my Zprobe settings in config.g
                                        M558 P1 H5 F120 T12000 ; Set Z probe type to unmodulated and the dive height + speeds
                                        G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
                                        M557 R125 S20 ; Define mesh grid
                                        Thanks for your help.
                                        Bart
                                        • DjDemonDundefined
                                          DjDemonD
                                          Okay hi. So best bet would be to use P5 mode in M558. Also use switch I1 which means an active low sensor.
                                          Set G31 P100.
                                          Please do not reverse the connector it might have very undesirable effects on either the Orion PCB or (more expensively) your Duet board.
                                          Let me know if this helps.
                                            zendesigner
                                            HI sImon,
                                            Thanks for your excellent help. I tried the low setting before but it hought it was L1 instead of I1. So kinda misread the font 😉
                                            Now the value is 0 and goes to 1000 is being tapped.
                                            Cheers
                                            Bart
