    Your Duet rejected the HTTP request: page not found
    Firmware installation
    20.5k
    • sleeplessundefined
      sleepless
      sorry about that. thanks for the picture it really helps
        sleepless
        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.0(RTOS) running on Duet WiFi 1.02 or later
        Board ID: 08DGM-9T6BU-FG3SJ-6J9D4-3S86T-TAXRD
        Used output buffers: 1 of 20 (1 max)
        Static ram: 28380
        Dynamic ram: 95740 of which 0 recycled
        Exception stack ram used: 300
        Never used ram: 6652
        Task NETWORK ready, free stack 1408
        Task HEAT blocked, free stack 1256
        Task MAIN running, free stack 3624
        Last reset 00:05:40 ago, cause: power up
        Last software reset at 2018-10-24 20:24, reason: User, spinning module GCodes, available RAM 6152 bytes (slot 0)
        Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0041f000, BFAR 0xe000ed38, SP 0xffffffff
        Error status: 0
        Free file entries: 10
        MCU temperature: min 26.1, current 30.3, max 30.4
        Supply voltage: min 12.3, current 12.3, max 12.5, under voltage events: 0, over voltage events: 0
        Slowest loop: 1.08ms; fastest: 0.07ms
        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
        Scheduled moves: 0, completed moves: 0
        Bed compensation in use: none
        Segments left: 0
        Movement lock held by null
        http is idle in state(s) 0
        telnet is idle in state(s) 0
        file is idle in state(s) 0
        serial is ready with "m122" in state(s) 0
        aux is idle in state(s) 0
        daemon is idle in state(s) 0
        queue is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 14.21ms; fastest: 0.01ms
        HTTP sessions: 0 of 8
        • WiFi -
          Network state is running
          Failed to get WiFi status
          === Expansion ===
          ok
          sleepless
          it looks like im in the -70 range which is bad. so i just need to be patient and wait for the network to see it.
          • T3P3Tonyundefined
            T3P3Tony administrators @sleepless
            @sleepless your Wifi does not appear to be up properly:
            Please can you send the following:
            M552
            M552 S1
            Also please share your config.g here
            www.duet3d.com
            sleeplessundefined 1 Reply Last reply Reply Quote 0
              sleepless @T3P3Tony
              @t3p3tony [0_1540514887260_config (1).zip](Uploading 100%)
                Phaedrux Moderator @sleepless
                @sleepless I think you'll have to upload it as a plain text file, or just copy and paste the contents into a post.
                  sleepless
                  ; generated by RepRapFirmware Configuration Tool on Wed Oct 24 2018 18:43:01 GMT-0700 (Pacific Daylight Time)
                  M550 PRobo_Duet1 ; Set machine name
                  M551 Psafety13 ; Set password
                  M552 S1 ; Enable network
                  M586 P0 S1 ; Enable HTTP
                  M586 P1 S0 ; Disable FTP
                  M586 P2 S0 ; Disable Telnet
                  M92 X80 Y80 Z800 E723.38 ; Set steps per mm
                  M203 X18000 Y18000 Z180 E1200 ; Set maximum speeds (mm/min)
                  M201 X500 Y500 Z5 E25 ; Set accelerations (mm/s^2)
                  M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
                  M84 S30 ; Set idle timeout
                  M208 X230 Y254 Z200 S0 ; Set axis maxima
                  M574 X1 Y2 Z1 S1 ; Set active high endstops
                  M558 P5 H5 F120 T6000 ; Set Z probe type to switch and the dive height + speeds
                  G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
                  M557 X15:215 Y15:239 S20 ; Define mesh grid
                  M143 H0 S110 ; Set temperature limit for heater 0 to 110C
                  M143 H1 S300 ; Set temperature limit for heater 1 to 300C
                  M563 P0 D0 H1 ; Define tool 0
                    sleepless
                    anyone can help with the robo3d r1 plus auto level and z home setup?
                      sleepless
                      OK I got all axis to home but cant get it to auto level. I read this https://forum.duet3d.com/topic/4737/zprobe-robo3d-r1/9 but am still confused. please help
                        Have you gone through https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe ?
                          sleepless
                          Should my z endstop be plugged into the z probe area instead of the z endstop area on the board? Sorry Im feel like im just getting more and more confused
                          Phaedruxundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                            @sleepless said in Your Duet rejected the HTTP request: page not found:
                            That's up to you depending on which probe mode you choose. Either mode 4 or mode 5 (or one of the slight variations (mode 6, 7, or, 8 which use different connection options.)
                            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
                            Mode 4
                            The trigger signal is read from the E0 endstop circuit. You can choose whether the signal is high or low when triggered. In firmware 1.15 and earlier this is done by using M574 E0 S1 to select active high, or M574 E0 S0 to select active low. In firmware 1.16 and later, use I1 in the M558 command to select active low, otherwise it defaults to active high. The device connected to the E0 STP pin must be able to sink 1.5mA for the Duet 2 WiFi and Duet 2 Ethernet, 0.3mA for the Duet 2 Maestro, or 2.1mA for the Duet 0.6 or 0.8.5.
                            Mode 5
                            A switch or digital output device connected between the IN and GND terminals of the Z probe connector. Similar to mode 4 except that the Z probe connector is used. The input must be active high when triggered, or in firmware 1.16 and later you can use the I1 parameter in the M558 command to select active low. The only pullup resistor is the 100K nominal pullup in the microcontroller so the sink current requirement is tiny.
                            Mode 6
                            Similar to mode 4 except that the E1 endstop input is used.
                            Mode 7
                            Similar to mode 4 except that the Z endstop input is used.
                            Mode 8
                            Similar to mode 5 except that the input is not filtered, for slightly faster response. Supported in firmare 1.20 and later.
                            It would help to know what type of switch it's using for the Z axis endstop, but I think you may want to use Mode 8, which would connect your switch to the Z probe connector.
                            • T3P3Tonyundefined
                              @sleepless do you have both a Z probe and a Z endstop or just a probe? Generally a Z probe would be plugged into the prob header.
                              edit @Phaedrux provided a far more detailed answer, posts crossed.
                              www.duet3d.com
                                Phaedrux Moderator @T3P3Tony
                                @t3p3tony The Robo3D appears to have 2 end stop switches wired in parallel for the z axis.
                                At least that's what I gathered from the thread linked above.
                                It looks like they used mode 4, inverted, wired to the z endstop pins.. But I think mode 8 connected to the z probe pins would also work.
                                  sleepless
                                  Thanks everyone so to clarify I am using the robo3d r1 plus stock endstops and autolevel. It uses microswitches that get triggered when the x axis is lifted off the endstop by the nozzle touching the bed. I will move the z endstop to the z probe connection and give it a go
                                    sleepless
                                    z probe seems to need the plug wired differently am I seeing that correctly?
                                      sleepless
                                      forgot to mention I only have endstops no z probe
                                        sleepless
                                        what is parameter I1?
                                        Connect it between the STP and GND pins of the E0 connector and select mode 4. If it is a normally-closed microswitch, then with version 1.15 or earlier firmware use M574 E0 S1 to select active high trigger level. For normally-open contacts (not recommended), send M574 E0 S0 instead. With 1.16 or later firmware, include parameter I1 in the M558 command if you are using a normally-open switch.
                                        Ok so if I understand this correctly I need to plug my Z endstop into the E0 Stop. I need to connect the black wire to the GRD and the Red wire into the E0 Stop pin ports. Then I need to send M558 parameter I1?
                                          I1 will invert the signal. That's an upper case i.
                                            sleepless
                                            Thanks for the quick replies ok ill give it a shot and see what happens. If the Z doesnt trigger how do I troubleshoot?
