Duet Wifi heats Bed and Hotend from start
Thanks for the hint. i renamed it and recognized that there was already a file like this in the sys folder. i replaced it anyways with the new one but i get the same result "installation failed..."
The Baud Rate is the data rate at which the main processor communicates with the Wifi chip, using the UART / Serial protocol.
The fact that it fails to get any response, tells me there is an issue where a trace between the 2 may have an issue.
The UART communication uses 2 data lines: TX (transmit) and RX (receive); the TX of one goes to the RX of the other. If a data line is damaged, the communication will fail.
One of the other guys might be able to tell you where to look for these traces.
okay, thanks. i guess you are right. i can do a firmware upgrade and everything works fine, but it looks like the processort cant communicate with the wifi chip properly. I can set the wifi to active and inactive but connecting to my wifi will result in an error every time. Additionally, as already pointed out, the update of the wifi firmware itself wont work...
My guess is that you had a transient or short to the 5V or the 3.3V power rail, which damaged both U11 and the WiFi module. So I think you need to replace the WiFi module. The good news is that it's easier to solder than U11 because the pads are larger.
The correct replacement part is ESP-12S, or ESP-07S (the S is important) if you want the version with external antenna. These are are readily available on eBay.
Please note, the other component that is easily damaged by over-voltage on the 3.3V rail is the main processor. So I suggest you check first that the processor is not getting hot (slightly warm is normal) and the other functions of the Duet are working properly.
From the photo, it looks like your Duet was revision 1.04, in which case it might still be under warranty.
@dc42 thanks for your informative answer. the WiFi Was working before i tried my soldering skills on the U11, thats why i wanted to figure out what i might have damaged
the Board is only 6 Weeks old thats why i asked the Internet Shop where i bought It if warranty is an option, but they refused. Do you think i should ask at the headquarters in uk? -
If the internet shop was one of our official distributors (see the list at the bottom of https://www.duet3d.com/DuetWifi) then they would typically refer warranty enquiries to us, unless they had reason to believe that the Duet had been abused.
they asked me to open this forum Post and After the First few posts they thought i damaged it myself, because the most likely reason was that i created a short.
it would be really nice if i could get warranty because i didnt Do anything harmful to the Board (at least i dont know about something). Do you think i should try to contact your Support Directly? -
I'll discuss this with my colleagues and we'll get back to you, probably by email.
thank You!
@dc42 i am maybe a bit impatient, but are there any news in this topic?
I'm sorry, one of my colleagues should have got back to you. I have chased them. We agreed the warranty replacement.
If you purchased directly from duet3d.com then you will need to complete the warranty form, see https://docs.google.com/forms/d/e/1FAIpQLSdyf6gGP_ncZachWi2HH7qx1kc5TE9WeEbz83VFBckm1JBXbQ/viewform.
@sixfeetunder please email info@duet3d.com if you have filled in the warranty form already, if not please fill that in as David has linked
this are great news. thanks! unfortunately i didnt buy it from duet3d directly, but from makerdise.com. how should i proceed under that circumstances? @T3P3Tony
