    Printing problems
    • ander
      ander last edited by
      Hi there! i,m working on my custom delta printer, everything works fine so far, i can move the axis well, the heating control works fine, the bed compensation works well....but when i try to print something, it starts heating up, then it makes the bed levelling and after that it stops and in the screen you can see the printing process bar being completed like in 20 seconds until reaches 100% and it goes back home. there is no error message in the console, just says it has been printed already but it does nothing. what can i check? i´m currently using simplify 3d but i also tryed cura, with same results
        Please make available to us one of the GCode files you are trying to print.
        • ander
          0_1540678374035_Twisted_Vase_Basic.gcode
          • ander
            hi there! i just wanted to say that i found the solution, the problem was on the simplify configuration, thanks
            • T3P3Tony
              T3P3Tony administrators @ander last edited by
              @ander can you share what it was to help people who have the same issue 😄
