    New RepRapFirmware config tool
    79
    10.3k
    • madhunmundefined
      madhunm @chrishamm
      @chrishamm said in New RepRapFirmware config tool:
      @madhunm Yes, I think I can add it soon but in the meantime I still have to have a look at a few DWC requests that have come up.
      understood; will look forward to the update when it happens. Thanks!
      • botundefined
        bot @chrishamm
        @bot Yes, support for DueX2/5 is already included. You can configure every heater+motor that is supported on a DueX5.
        I'm not sure I'm seeing this, except for extruders. Where can a U, V, and W axis be created?
        How would one configure an idex printer using this tool?
        *not actually a robot
          dc42 administrators @chrishamm
          @garyd9 The 'R' parameter is basically obsolete for Duets newer than the 0.6 because it defaults to 4.7kOhm in the firmware. I'll add it back for consistency, though.
          On the Duet 2 Maestro, the series resistor is 2.2K, not 4.7K. I think it's best to leave it out of M305 commands and let the firmware provide the default.
          • chrishammundefined
            chrishamm administrators @dc42
            @dc42 Yes, of course you're right, sorry - I accidentally looked in my outdated RRF directory when I looked it up.
            Duet software engineer
            • mikebridgeundefined
              mikebridge @chrishamm
              @chrishamm Yes, I meant having the firmware update the .json if changes are made to the .g system files manually, but I guess that would be more of a DWC change
              375x360x415 CoreXY DuetWifi + Duex5
              24v 600w, E3D Chimera, Zesty Nimble CC, BLTouch, X&Y linear rails, dual Z motors
              • OBELIKSundefined
                OBELIKS
                Sorry to dig up this thread.
                I have a question regarding the thermistor coefficient calculator.
                I remember seeing that there were some changes in code for this, but I cant find the thread where it was discussed.
                So in the new version I get this:
                In the old one:
                And that lines up with:
                What is the correct value?
                Also every time I go in to custom calculation the default R25 value is 10000 instead of 100000
                P3Steel Toolson mk2 - Duet 2 WiFi --> RatRig V-Core with Duet WiFi 1.03
                Original Prusa i3 MK3S
                • wilrikerundefined
                  wilriker @OBELIKS
                  @obeliks The documentation says
                  Bnnn If the sensor is a thermistor, this is the Beta value. For the Steinhart-Hart thermistor model, this is the reciprocal of the B coefficient
                  So in your case
                  1 / 5090 = 1.96464e-4
                  though given this is not clear at all from what is displayed.
                  Manuel
                  My Tool Collection
                  • OBELIKSundefined
                    OBELIKS
                    OK, thanks
                    Are then the presets wrong?
                    • wilrikerundefined
                      wilriker @OBELIKS
                      @obeliks Which presets do you mean?
                      Manuel
                      My Tool Collection
                      • OBELIKSundefined
                        OBELIKS
                        Never mind, completely false alarm. The B values were visually so close to old beta values that I was under the impression we are looking at the old ones.
                        Thank you for the explanation and sorry for the confusion.
                        • botundefined
                          bot
                          Am I crazy, or is there no way to configure an IDEX printer, or any printer with a duex attached, using the configuration tool?
                          I see no way to add a U axis. I see no way to reference the fans on the Duex.
                            The online configurator doesn't cover advanced configurations such as IDEX. You will need to edit the config.g file to create the new axis and assign the correct fans. See https://duet3d.dozuki.com/Wiki/ConfiguringMultipleIndependentXcarriagesCartesian
                            botundefined 1 Reply Last reply Reply Quote 1
                            • imrjundefined
                              imrj
                              Great work!!
                              • botundefined
                                bot @dc42
                                @dc42 thanks, I will make my own files.
                                  You can use the configurator to generate most of the commands, by telling it you have a dual extruder machine. Then edit the resulting files to account for IDEX.
                                  • botundefined
                                    bot
                                    That is what I ended up doing. I'm well on my way and finally getting a hang of all the changes since I last configured a new printer.
                                    • DunstonUKundefined
                                      DunstonUK
                                      It is using the old M667 S1 command for CoreXY where I believe it should be M669 K1.
                                      Also, all files in the homing files list items such as; " lift Z relative to current position" when the bed drops as the gantry is fixed, is this not possible to be corrected so the file wording reflects what it actually does.
                                      Life’s bucket list is never ending. Remember someone else is always better than you.
                                      • T3P3Tonyundefined
                                        T3P3Tony administrators @DunstonUK
                                        @DunstonUK said in New RepRapFirmware config tool:
                                        This is correct in my view because Z increases as the bed drops on a printer with a bed that movers in Z. Bed down is equivalent to gantry up, and the firmware does not know what configuration your hardware is in. A possible clarification would be "Increase Z distance..." Rather than " Lift Z...."
                                        www.duet3d.com
                                        DunstonUKundefined 1 Reply Last reply Reply Quote 0
                                          DunstonUK @T3P3Tony
                                          @T3P3Tony
                                          Yes, but also you have to select what type of printer you have at the start, and as I do not see CoreXY as a choice its always "Custom configuration", which is chosen, unless you have one of the ones listed, also for those who have lets say a Corxy with 3 x Z rods/screws/rails, there is no tool selection for that type or not? I am relatively new to 3D printing, but I do see that these tools and configurators are not always made with the novice in mind, who may not fully grasp the wording used, because the wording used is not always clear and can lead to more confusion and more posts asking the same questions over and over again. Please do not misunderstand me, these tools are a godsend, without it I would be posting even more questions that I do, and I tip my hat to those who have written it with full respect.
                                          • T3P3Tonyundefined
                                            @DunstonUK sure - custom configuration and then choose corexy at some point in the future we will hopefully have more corexy printer types: Railcore II, e3d Toolchanger, H Bot etc but unless you had one of those you would still need to use custom, then coreXY.
                                            no advanced options like that are not yet part of the config tool.
                                            www.duet3d.com
