    New RepRapFirmware config tool
    79
    10.3k
    • steevebeckerundefined
      steevebecker @Veti
      @Veti I have partially the same problem
      in the I/O Mapping Tab, I have added : +1 Driver for the second extruder, +1 Heater, +1 Fan
      pin out everything
      but then in the Tool Tab, tools there is only FAN0 available for any tool.
      I/O TAB:
      Fan TAB seems ok:
      But then in the Tool TAB
      plant your ideas, water suggestions and questions, collect progress and do great things.
      • Vetiundefined
        Veti
        ignore my comment above its working.
        @steevebecker
        you need to disable thermostatic control for another fan.
          steevebecker
          @Veti Make sense ! It works
          • jlipavsky79undefined
            jlipavsky79
            is this stable for duet3 config?? Also..... im setting up a duet3 as a cnc controler...
            How about cnc stuff???? A tab for cnc config like for the spindle speed output setting, for turning on and forward and reverse. Configuring for a vac system for triggering through gcode.... maybe for coolant pumps through gcode..... probing like digitizer probe.....
            • T3P3Tonyundefined
              T3P3Tony administrators @jlipavsky79
              @jlipavsky79 that's a good point, we do need to extend the config tool for CNC and Laser modes of operation. I hope some of the CNC experienced on the forum can suggest good options and reasonable defaults.
              www.duet3d.com
              • renehundefined
                reneh @chrishamm
                @chrishamm Hi, great work. I try to use this tool in safari browser 13.04 bud I can not open/edit XYZ Offsets in the too tab. Could you tell me please how can I fix this?
                • Danalundefined
                  Danal
                  You should get a "popup" or "overlay" like this:
                  Does safari have any way to turn off popup blocking?
                  renehundefined 1 Reply Last reply Reply Quote 0
                  • PaulHewundefined
                    PaulHew
                    Please could you look at the issue in regards to selecting BLTouch as a probe type for the Ender3 template with RRF3 in the config tool.
                    It is currently greyed out and is unselect-able.
                    I mentioned it in a previous post and DC42 informed me he would look into it.
                    Veti gave me the lines I need for it to work, mapping the pins.
                    Thanks
                    Paul
                    RailCore II - Duet Mini + 1LC, Voron V0.1 - Duet Mini
                    Voron 2.4 disassembled..... Waiting for the RailCore Mini....
                    • chrishammundefined
                      chrishamm administrators @PaulHew
                      @PaulHew said in New RepRapFirmware config tool:
                      Thanks
                      Paul
                      I can select the BLTouch with RRF2 and RRF3 but in order to select it with RRF3, you need to assign the PWM Control Channel on the I/O Mapping page first. Then you can activate BLTouch on the Endstops page.
                      Duet software engineer
                      • PaulHewundefined
                        PaulHew
                        @chrishamm Thanks for the fast reply!
                        I have a Duet Maestro board.
                        On the I/O mapping page I cannot select any of the 'PWM Control Channels (BLTouch only).
                        I can see them in the drop down but they are not selectable.
                        My thinking was if I was able select BLT on the Endstops page it would automatically create the I/O mapping.
                        Edit: Also on the Endstops page I cannot select 'Z Probe' for the Z axis
                        Regards,
                        Paul.
                          @PaulHew You must set "Z Probe Mod Pin" to (not assigned) before you can use it in the input below. I'll consider that suggestion.
                            chrishamm administrators @reneh
                            @reneh There was a problem in the configtool that prevented the popup from being shown on OS X. It has been fixed in the latest version (2.1.8).
                              jay_s_uk
                              @chrishamm Is there a github repo for the config tool where issues can be raised to make them easier to track like there is for DWC?
                                chrishamm administrators @jay_s_uk
                                @jay_s_uk said in New RepRapFirmware config tool:
                                Yes, it's on GitHub.
                                • PaulHewundefined
                                  PaulHew
                                  @chrishamm Again, thanks for the speedy reply.
                                  Ok I have done that and I was able to eventually select Z-Probe and then select BLT. Thank you.
                                  I program, but not what you clever guys write.
                                  As another suggestion for the I/O mapping page, based on selecting the Ender3 template with a Maestro board could there be a tick box for say 'If using a BLTouch check this box'
                                  Which then selects the correct options, using the Ender3 template with a Maestro board makes the changes needed to the I/O mapping page and the Endstop page.?
                                  • renehundefined
                                    reneh @Danal
                                    @Danal
                                    Hi, in google chrome i get such a popup but not in safari. In safari popups not blocked. strange phenomenon. Is there any other safari setting in safari that i need to consider?
                                    Thank you
                                    • infiniteloopundefined
                                      infiniteloop
                                      @reneh said in New RepRapFirmware config tool:
                                      Have a look at this guide …
                                        Technically it isn't a pop-up, it's just a div. @reneh try to clear your browser cache and it should work again.
                                        • renehundefined
                                          reneh
                                          Hi all, it works. Thank you very much
                                          Bye
