    Short circuit error on Kossel XL with duet wifi
    4.3k
    • T3P3Tonyundefined
      T3P3Tony administrators
      Sounds like you have a faulty thermistor or faulty wires between the board and the thermistor on your hotend.
      www.duet3d.com
      • oogwayundefined
        oogway
        @T3P3Tony:
        Ok I'll look into replacing the thermistor. Is it possible I blew that little board that sits above the hotend? The one i plug everything into.
        • T3P3Tonyundefined
          Ahh hold on. I did not realise you had a hotend PCB. That is another point where there could be an error. So measure the resistance of the the thermistor at the plug that plugs the thermistor into the hotend PCB. Also measure the reisitance of the connection from the hotend PCB back to the plug onto the Duet. The thermistor should be 100K ( the wires should be almost 0 Ohms.
          www.duet3d.com
          • oogwayundefined
            oogway
            So i measured the pictured black and green wires and got a resistance of .010 when the mm is set to 2M. Hope that's normal.
            https://postimg.org/image/qfql2u489/
            I measured the resistance of the thermistor plug (link to picture in a previous post) and got the same .0l reading.
            Thanks for all of your help so far everyone. I'm a total noob. lol
            • oogwayundefined
              oogway
              Does anyone know where i can find the hotend pcb? I tried looking on the E3D website and the Think3dprint3d website but did not see it.
              Was also wondering this…since my hotend pcb still powers on my 2 fans connected to it...is it safe to assume that it's ok? I'm now thinking it's just the thermistor that needs to be replaced..
              • T3P3Tonyundefined
                The Hotend PCB is on Github here:
                https://github.com/T3P3/KosselHotendBoard
                It certainly sounds like a new thermistor is the most likely.
                www.duet3d.com
                • oogwayundefined
                  oogway
                  @T3P3Tony:
                  Awesome, I'll start there. Should i replace both wires coming out of my hotend? or just the thicker red one?
                  • oogwayundefined
                    oogway
                    Just to confirm, it was my thermistor. I replaced it and it heated up immediately. Thanks for the help everyone!
