    Firmware 2.02RC5 now available
    Firmware installation
    14
    47
    4804
      I've just released this at https://github.com/dc42/RepRapFirmware/releases/tag/2.02RC5. It includes changes for CNC users, improvements to the 12864 display system on the Duet Maestro, other minor changes, and bug fixes. As always, read the upgrade notes before you install it.
      I hope this will be the last RC before the 2.02 release.
      Feedback:
      • If you try this release and it works well for you and/or fixes problems that you encountered with previous releases, please report that in this thread.
      • If you find any problems with this release and you have already read the upgrade notes and made any necessary changes to other files, please create a new thread with a title of the form "Release 2.02RC5 issue: " followed by a summary of the issue in a few words. It's hard for me to track multiple issues from different users in a single thread
      • appjaws
        appjaws last edited by
        No problems with coreXYUV printer.
        Thank you David for all your hard work
        appjaws - Core XYUV Duet Ethernet Duex5
        firmware 3.3RC1+1 Web Interface 3.3.0-RC1
        Ormerod 1-converted to laser engraver, Duet wifi
        OpenSCAD version 2020.07
        slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
          No issues noted thus far.
          • 3dmntbighker
            3dmntbighker last edited by
            Seemed to work last night.
            Scratch built CoreXY with Maestro
            Heavily modified Ender 3 with Maestro
            MPCNC work in progress with Duet WiFi
            • zzing
              zzing last edited by zzing
              9:45:28 PM
              Finished printing file 20mm_cube.gcode, print time was 0h 34m
              9:44:42 PM
              Error: Internal Error in Read at ../src/Storage/FileStore.cpp(281)
              Error: Internal Error in Close at ../src/Storage/FileStore.cpp(148)
              9:11:28 PM
              M290 S-0.05
              9:11:05 PM
              M32 "20mm_cube.gcode"
              File 20mm_cube.gcode selected for printing
              This is the only issue I have noticed with RC5.
                dc42 administrators @zzing last edited by dc42
                @zzing said in Firmware 2.02RC5 now available:
                9:45:28 PM
                9:44:42 PM
                9:11:28 PM
                M290 S-0.05
                9:11:05 PM
                Have you any idea what provoked the Internal Error messages? I presume you didn't remove the SD card before the print finished?
                • frafa
                  frafa last edited by frafa
                  Hi David
                  Test 2.02RC5 on my Scara
                  Homing ok 🙂 --> oup's ko 😞
                  But after homnig absolute movement return error
                  possible move just on relative movement ...
                  Move on G90 impossible ...
                  G90 ; absolute movement
                  G1 Y0 X0 F1000
                  Error: G1/G2/G3: intermediate position outside machine limits
                  UPGRADE ...
                  David if i remove G1 S2 X1 Y-1; on my homeall.g before G0 I always have the same error as on the versionn 2.02RC4 brief G30 does not work and homig is wrong ...
                  ; Home Z ir-probe
                  G91; Add test ...
                  G1 S2 X1 Y-1; Add test ...
                  G90; absolute movement
                  G30; Single Z-Probe
                  In short on scara I have the same concerns as on version 2.02RC4
                  Scara with DuetWifi => Scarlette3D
                  https://youtu.be/mBF5cO8vGhI
                  • giostark
                    giostark last edited by giostark
                    I'm still facing the perfect ,or more possible accurate ,calibration. And in the meanwhile I discovered a bug.
                    If I use the microstep 0.05 from the WC by pressing the Z-Baby stepping button, before or after a manual extrusion always from the WC ,the printer replicate the same extrusion as an other manual input (see picture ) . If this happen when the filament is near the nozzle occur the muse bite because the gears run faster the capability of the nozzle to release the material . (this because the manual extrusion for load the filament is done fast - my printer have near 15cm between the nozzle and the extruder gear)
                    I can reproduce this as many time I want.
                    • k3lag
                      k3lag last edited by
                      Working fine on my dual idex bigbox
                        dc42 administrators @giostark last edited by
                        @giostark said in Firmware 2.02RC5 now available:
                        Thanks for reporting this, it's on my list to investigate.
                        • Gone2Far
                          Gone2Far last edited by
                          Working fine on homebrew kossel.
                          Original Prusa i3 MK2S
                          Large Kossel Homebrew
                          • zzing
                            @dc42 correct, no pulling of SD. There really wasn't anything I was doing directly, except for being in proximity to it.
                              dc42 administrators @frafa last edited by
                              @frafa said in Firmware 2.02RC5 now available:
                              Are you certain that X0 Y0 is accessible in a straight line from the initial position? What happens if you use G0 instead of G1?
                              This is the homeall.g file on my SCARA:
                              ; Home All file for Robotdigg SCARA arm printer
                              M561			; cancel bed compensation
                              G91
                              G1 S2 Z28 F1000		; raise Z to keep nozzle clear of base frame
                              G1 S1 X200 Y200 F1000	; home proximal and distal arms
                              G1 S2 X-5 Y-5 F1000	; back off
                              G1 S1 X10 Y10 F200	; repeat the homing more slowly
                              G90
                              G1 X-75 Y75 F3000	; move to a position that correspond to one of the M557 grid points
                              G30			; home Z
                              G1 Z28 F1000		; move to safe height again
                              G29 S1			; load height map
                                dc42 administrators @dc42 last edited by
                                @dc42 said in Firmware 2.02RC5 now available:
                                I confirm this issue. It will be fixed in 2.02RC6.
                                • Danal
                                  Danal last edited by Danal
                                  Installed and working on a Larg-ish delta (600mm x 600mm). No issues found so far. Have done a couple of prints, one of them about six hours.
                                  And... this did clean up the HTTP line ends (reported in a separate thread, now marked resolved).
                                  • resam
                                    resam last edited by resam
                                    Some odd behaviour during pause & resume:
                                    I have this in my resume.g:
                                    G1 R1 X0 Y0 Z3 F6000     ; return to point previously paused at (but above it)
                                    G1 R1 X0 Y0 Z0 F180      ; return to point previously paused at (lower nozzle)
                                    G1 R1 X0 Y0 Z3 actually moves to X0 and Y0 - instead of the "last saved point".
                                    Then it move 3mm down.
                                    Then it seems to continue to the correct "last saved point" location (not sure if this is still from with resume.g or already the next commanded move from my print code).
                                    Now it obviously crashes because the nozzle is too low.
                                    This is repeatable. Print something for a few minutes. Pause. (I usually do a filament change or clear a heat-creep and command some manual extrusion to prime the nozzle). The Resume. Then crash (if I'm not quick enough with the E-stop).
                                    I might have tweaked my config - but I don't see anything obvious in my version-controlled config files...
                                    @dc42 Should G0 R1 X0 Y0 behave the same as G1 R1 X0 Y0?
                                    edit: I just flashed RC4 again - and the problem is gone. So this is a regression in RC5.
                                    • frafa
                                      @David
                                      I have exactly the same problems as with version 2.02RC3
                                      https://forum.duet3d.com/topic/7316/firmware-2-02-release-candidate-3-now-available/70
                                      tested with your homing.all file adapted to my config, the same errors ...
                                      Downgrade 1.21RC3 waiting ...
                                        dc42 administrators @resam last edited by
                                        @resam said in Firmware 2.02RC5 now available:
                                        Strange, nobody else has reported this and I have similar lines in resume.g. I will test it again.
                                        RRF restores the last print position automatically immediately before resuming. Using G1 R1 commands is optional, and allows you to control how it is done. G0 R1 should behave the same as G1 R1 except that on some machines (e.g. SCARA) the movement may not be linear.
                                        resam 1 Reply Last reply Reply Quote 0
                                        • resam
                                          resam @dc42 last edited by
                                          @dc42 I have a corexy. With RC4 it works as expected. RC5 moves to the wrong position.
                                          I suspect the G53&G54 changes might have introduced a bug?
                                            Were you using workplace coordinate offsets when this happened?
                                            • resam
                                              No - I'm running in a simple plain FFF mode as 3D printer.
                                              I do not have any G53 or G54 codes in my sys/ or macros/ files.
                                                dc42 administrators @resam last edited by dc42
                                                Thanks. Are you using any G10 tool offsets?
                                                EDIT: or M206 offsets?
                                                • resam
                                                  resam @dc42 last edited by resam
                                                  The only G10's I have are hotend temperature and retract commands:
                                                  G10 10 P0 S0 R0, G10 S175 and similar.
                                                  No.
                                                  I do have a M208 with a negative Y minima - which I use as a pause position - maybe this is causing a weird edge case ("out of workspace"?)
                                                  My pause.g:
                                                  M83                      ; relative extruder moves
                                                  G1 E-2 F1200             ; retract
                                                  G91                      ; relative moves
                                                  G1 Z3                    ; raise nozzle
                                                  G90                      ; absolute moves
                                                  G0 X230 Y-5 F6000        ; move head out of the way of the print and clear nozzle
                                                  M106 S0                  ; fan off
                                                  My resume.g:
                                                  G0 R1 X0 Y0 Z3 F6000     ; return to point previously paused at (but above it)
                                                  G1 E2 F1200              ; undo the retraction
                                                  M106 R1                  ; restore fan speed
                                                  T R1                     ; restore tool selection
                                                  I based these scripts on https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Pause_resume_and_cancel_files - but it seems some of it is redundant now because RRF already does the same steps before/after calling resume.g
                                                    Even though the G0 R1 and G1 R1 lines are not strictly needed, they should still work, at least if you are not using workplace coordinate offsets or tool offsets. As you are not using either of those, I don't know why they are not working properly. The negative Y coordinate is OK. I tested pause/resume in 2.02RC5 using this resume.g file:
                                                    ; Resume macro file
                                                    G1 R1 X0 Y0 Z2 F5000 ; move to 2mm above resume point
                                                    G1 R1 X0 Y0 Z0 ; lower nozzle to resume point
                                                    G1 E4 F2500 ; undo the retraction
                                                    • resam
                                                      I flashed RC5 again - the bug is repeatable.
                                                      I added beeps to my resume.g to check when the faulty moves are made:
                                                      The G1 R1 ... commands in resume.g are not correctly executed. The head seems to be moved to (0,0) in absolute coordinates (front left corner).
                                                      The following similar moves in the firmware seem to be correct.
                                                      With RC4 this works as expected.
                                                      So this bug seems to happen somewhere during/before the execution of resume.g, because once we enter the resuming_1 state, it behaves correctly.
                                                      HandleMCode for case 24 is pretty simple - so I suspect DoFileMacro again...
