    Smart Stepper?
    • 3dmntbighker
      3dmntbighker last edited by
      Anybody working on using these with a Duet?
      http://misfittech.net/nema-17-smart-stepper/
      Scratch built CoreXY with Maestro
      Heavily modified Ender 3 with Maestro
      MPCNC work in progress with Duet WiFi
      • madude91
        madude91 last edited by
        I am interested to know how they work with Duet too.
          I have been unable to find any user manual or specification for this device, so I can't tell whether it is compatible. I have posted a question at https://groups.google.com/forum/#!topic/smart-stepper/a3IRc89yG5E.
            I have had a reply to my question. It looks like you should be able to use the Smart Stepper connected to the expansion connector or to the CONN__LCD connector. Connect the step, direction, enable and ground pins on the Smart Stepper in the obvious way. Connect the VIN pin of the Smart Stepper to +3.3V on the Duet. In the M569 command for that driver, I suggest T1:2:20:0. If you get missed steps, you may need to increase one or more of those values.
            • vmario89
              vmario89 last edited by
              it's an old topic but for all who found this: https://github.com/Misfittech/nano_stepper/issues/40
              i documented some stuff for wiring up the smart steppers with a Duet 2. Until yet i had no problems with missed steps yet. I did not configure the T parameter.
              by the way what are the default values for step pulse width, step pulse interval, direction setup time and direction hold time ?
              vmario89 created this issue in Misfittech/nano_stepper
              closed Duet Board Support #40
              zapta dc42 2 Replies Last reply Reply Quote 0
              • zapta
                zapta @vmario89 last edited by
                @vmario89, what are the advantages of having that smart controller between the duet and the motor?
                  dc42 administrators @vmario89 last edited by
                  @vmario89 said in Smart Stepper?:
                  As fast as the Duet can generate them, which is well under 1us. The Trinamic drivers need only about 100ns.
