    Consistent ripples on prints
    33
    4.4k
    • Agniusmundefined
      Agniusm
      On genuine duet board there are C shaped artifacts that you might not see in photos clearly, 2 at the very right side are more visible (red sample) on x axis photo (still it might be caused by minuscule upobservable differences in machines) .
      Somehow i lean towards motor incompatibility to duet. Blind guess but those motors are not made equal.
      3dmntbighkerundefined 1 Reply Last reply Reply Quote 0
      • 3dmntbighkerundefined
        3dmntbighker @Agniusm
        @agniusm said in Consistent ripples on prints:
        Yeah, were I in your position I might order a similar stepper that is "supposed" to be a bit better quality and try it. It won't break the bank.
        Scratch built CoreXY with Maestro
        Heavily modified Ender 3 with Maestro
        MPCNC work in progress with Duet WiFi
        • Agniusmundefined
          Agniusm
          I have ordered couole of these motors: https://www.omc-stepperonline.com/nema-17-stepper-motor/nema-17-bipolar-09deg-44ncm-623ozin-168a-28v-42x42x47mm-4-wires-17hm19-1684s.html?mfp=149-step-angle[0.9]
          Are they OK? Just to remind, for 24V system
          • Agniusmundefined
            Agniusm
            I have been contacted by a member with the same issue on completly stock unit. I can strike out extruder now without even bothering testing it.
            Motors shoukd be next week but i am off with kids to rehabilitation center so next weekend maybe.
            hussainsail2002undefined 1 Reply Last reply Reply Quote 0
            • hussainsail2002undefined
              hussainsail2002 @Agniusm
              @agniusm Hi,
              Any update on this ?
              Agniusmundefined 1 Reply Last reply Reply Quote 0
              • Agniusmundefined
                Agniusm @hussainsail2002
                @hussainsail2002 Yes, i have swapped for 0.9 degree stepper motors and the problem is gone to a minimum. The ripples do not feel physically anymore
                hussainsail2002undefined nopheadundefined 2 Replies Last reply Reply Quote 0
                • robmundefined
                  robm
                  I think this is somehow a weakness of the cartesian / 'i3' design. I go back to fighting it now and then, but don't see it on my delta or the one print I've done on my new-to-me corexy.
                  Agniusmundefined 1 Reply Last reply Reply Quote 1
                  • Agniusmundefined
                    Agniusm @robm
                    @robm It must be. On other designs both x and y are more or less weight balanced and the print stays put.
                      @agniusm Thanks I had the rippling on my MKS board , when I changed to duet it got eliminated.
                      Any Idea what the reason behind this could be ?
                      • nopheadundefined
                        nophead @Agniusm
                        @agniusm Did the spacing change (assuming you can still see a lesser effect)?
                        • Agniusmundefined
                          Agniusm @nophead
                          @nophead Its very hard to see, basically impossible. i will see if i have old sample to get you photo comparison
                          P.S. Black with 1.8 motor, clear with 0.9 motor if you can spot the difference
                          • nopheadundefined
                            nophead
                            Black shiny plastic is always the worst for showing defects in my experience, so comparing it with clear is always going to be difficult and anything clear or white is hard to photograph with detail.
                            • Agniusmundefined
                              Agniusm @nophead
                              @nophead yes bit the ripples were visible on clear too. Now they are gone.
