    Filament config?
    filament config macro
    4814
    • 3dmntbighker
      3dmntbighker last edited by
      Out of curiosity, how many people have started using the filament config file? What are you putting in there?
      Scratch built CoreXY with Maestro
      Heavily modified Ender 3 with Maestro
      MPCNC work in progress with Duet WiFi
      • fucx
        fucx last edited by
        I'm not using it myself (yet), but I imagine one could put things like extrusion factor settings in there. But then again, these would also go into the load macro, so I'm not entirely sure what's the "correct" way of doing things here…
        • genghisnico13
          genghisnico13 last edited by
          I am using it to set Nozzle and bed temperatures, Extruder steps/mm, filament Flow/Diameter, Retraction and Non-linear Extrusion, so I have a config per roll that gets updated when initial calibrations are performed.
          Since I didn't like the flexibility of cura materials (at least from a while ago) now I manage all material parameters with config Files in the Duet.
          briskspirit 3dmntbighker 2 Replies Last reply Reply Quote 1
          • briskspirit
            briskspirit @genghisnico13 last edited by
            @genghisnico13 So slicer's settings will be ignored? For temp and etc. And can you show your files please?
            genghisnico13 1 Reply Last reply Reply Quote 0
            • 3dmntbighker
              3dmntbighker @genghisnico13 last edited by
              @genghisnico13 said in Filament config?:
              Very interesting
              • genghisnico13
                genghisnico13 last edited by genghisnico13
                Inside each Filament Config Macro:
                M350 E16 I1		;Back to 16 microstepping to set it.
                ;NonLinear Extrusion
                M92 E433.5 ;Adjusted for optimal curve fitting
                M592 D0 A-0.00051 B0.00061 ;Nonlinear Extrusion parameters
                M221 S101		;Flow(Diameter Compensation)
                ;Restore Microstepping to its value
                M98 P0:/Macros/MotorControl/SetExtruderMicrostepping.g
                ;Set Temperatures
                M140 S60			; Set Bed Temperature
                G10 P0 R140 S215		; Set Nozzle Active and Standby Temperature
                In this case FW Retraction (Pressure Advance also) is not configured because its the same as the one in the General Config file for PLA. And you can ignore the microstepping part, it's there so I can change the microstepping without editing all the Filaments config Files.
                The Slicer start G-code calls a PrePrint macro:
                M703		; Load Filament specific config, including Temps
                T100 P0		; Sets T0 to Standby Temperature, after the T0 issued by the Slicer
                M116 H0		; Wait for Bed Temperature to be reached
                T0 P0		; Selects Tool 0 (active temp), without executing Tool-change Macros
                G28
                G29 S1		; Load Grid Compensation
                G0 X320		 ; Move X to ooze Land
                M116		; Wait for All Heaters
                M98 P0:/Macros/Priming/PrimeOnBed.g
                • genghisnico13
                  genghisnico13 @briskspirit last edited by
                  @briskspirit I disabled Temperature Control from the addon "printer settings" in the cura "marketplace".
                  • 3dmntbighker
                    3dmntbighker last edited by 3dmntbighker
                    I have dipped a toe in by setting baby stepping -0.2 for PLA since it likes more squish than PETG. M290 R0 S-0.2 Is this the wrong approach? I could set the offset in the slicer I suppose. genghisnico13, you are a mad man 😉
                    edit: So much for that idea. It doesn't survive a power cycle.
                      Phaedrux Moderator @3dmntbighker last edited by
                      @3dmntbighker If you have a custom config.g setup for the filament you can load it at startup so it should be applied again after a power cycle.
                      Baby stepping is different than the live Z adjust in Marlin, etc. It's not a permanent change.
                      3dmntbighker 1 Reply Last reply Reply Quote 0
                      • 3dmntbighker
                        3dmntbighker @Phaedrux last edited by
                        @phaedrux said in Filament config?:
                        I added it to my PLA profile in S3D. It works fine there. I'm sure there are multiple ways to accomplish a Z offset like that. It's nice to have a flat stable bed that a 0.05 offset is actually useful for. I think I got super lucky with my Ender 3. I have not even bothered to change the wimpy bed springs. My first layers are pr0n-O-graphic 😉
                          @3dmntbighker I think you may be missing M703 to execute the filament specific config.g file.
                          https://duet3d.dozuki.com/Wiki/Gcode#Section_M703_Configure_filament
                          • 3dmntbighker
                            3dmntbighker @Phaedrux last edited by 3dmntbighker
                            Hmm, I added M703 to to tpost0.g and config.g still only runs at the time you load the filament. The filament name loaded survives a power cycle, but PLA/config.g is not run again after a power cycle? Or do you need the M703 in both tpost0.g and sys/config.g? If I deselect tool0 and select it again it looks like M703 doesn't run either. I have to unload and reload the filament.
                              @3dmntbighker I could see needing to add it to config.g, but it doesn't sound like it's working as intended. I think @chrishamm developed this functionality?
                              • AlexLin
                                AlexLin last edited by
                                I added M703 in start.g.so at the beginning of a print all filaments specifics are loaded
                                3dmntbighker 1 Reply Last reply Reply Quote 1
                                • 3dmntbighker
                                  3dmntbighker @AlexLin last edited by
                                  @alexlin said in Filament config?:
                                  I have a stop.g but no start.g?
                                    @3dmntbighker you can create it. It will be run first at the start of every print before the slicer start gcode.
                                    I use it to do a preheat and home the printer, reset any extrusion or speed factors, reset baby stepping, and play a little tune.
                                    • 3dmntbighker
                                      S3D does a lot of that for you in the start code. But putting it in Duet code and purging your slicer means you don't have to worry what slicer you are using I suppose.
                                      I was thinking yesterday that we need a pinned thread of people's musical code 😉
                                        @3dmntbighker Agreed! Here's mine: https://www.dropbox.com/sh/24m8me9jieqk725/AACJMSA0qlxw3KPLf_cjIVT5a?dl=0
