    Join filaments....
    • peirof
      peirof last edited by
      I have leftover rolls of filament, and I would like to take advantage of them ....
      I have consulted with Google, and I have seen that there are many systems, from the most DIY to methods that use specialized equipment (And expensive)
      One of the ones I've seen, which seems the most reasonable is this:
      Guide to fuse filaments
      The only doubt I have, is that the temperature reached by the hair iron is 230 degrees, maybe something more ... but not much ... for PLA, I imagine that well, ABS ... will be in the limit and PETG , I have my doubts .... I do not think that the temperature that has to be reached to join the filament, has to be that of extrusion.
      Has anyone tried this system?
      Any other system to join filaments?
      Thank you
      • Danal
        Danal last edited by
        Quote from linked article:
        Remove the PTFE tube by sliding it along the filament.
        Huh? That would be a LONG way...
        gtj0 1 Reply Last reply Reply Quote 0
        • gtj0
          gtj0 @Danal last edited by
          @danal said in Join filaments....:
          Depends on which way you slide it. 🙂
          • Torro
            Torro last edited by
            I've done that often. A short piece of bowden tube, a ligther and some sanding paper. That's all you need.
            • Danal
              Danal last edited by Danal
              OK, in all seriousness, I'm missing something about "slide off the tube".
              My primary case for WANTING to join filament is to use an "end of roll". That may still have 40 meters on it. Am I really supposed to slide the tube over all of that?
              Or even two half full rolls. Maybe there a filament detector and pause would be better... if I'm there to change it... so maybe I do still need to join two half rolls. Surely I'm not supposed to slide that tube for 150 meters?
              Stephen6309 1 Reply Last reply Reply Quote 0
              • Stephen6309
                Stephen6309 @Danal last edited by Stephen6309
                @danal Just leave the ptfe tube in place, it shouldn't get past the extruder. It'll come off when the filament runs out.
                Danal 1 Reply Last reply Reply Quote 1
                • Danal
                  Danal @Stephen6309 last edited by
                  @stephen6309 said in Join filaments....:
                  That sounds pretty reasonable, thanks!!
