    Starting a new print after canceling a print
    • mrehorstdmd
      mrehorstdmd last edited by
      I have noticed that if I cancel a print from either the touchscreen or DWC, then try to start a new one, it never seems to work right (heaters won't turn on, etc.). I get it working again by cycling power (a reset would probably work, too). Is that a problem with my configuration, or is that just the way RRF works?
      I'm am work and can't post a config file right now...
      garyd9 dc42 2 Replies Last reply Reply Quote 0
      • garyd9
        garyd9 @mrehorstdmd last edited by
        @mrehorstdmd It's not normal. I start prints frequently after canceling another without restarting the machine.
        "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
        • timcurtis67
          timcurtis67 last edited by
          If you cancle from the touch screen (PanelDue) you have to activate the heaters by touching each one so they turn red again. 3
          Then just restart the print.
          garyd9 1 Reply Last reply Reply Quote 0
          • garyd9
            garyd9 @timcurtis67 last edited by
            @timcurtis67 That depends on the contents of your cancel.g file. On my printer, cancel.g is empty and the tools remain active.
            It's hard to know what to suggest without seeing the config.g and cancel.g (and perhaps pause.g if the printer is paused before the print is canceled.)
              dc42 administrators @mrehorstdmd last edited by
              @mrehorstdmd said in Starting a new print after canceling a print:
              I'm guessing that you have T0 in your config.g file and that you don't have a cancel.g file. In that case, when you cancel a print it will deselect the current tool. Then when you start a new print, if it doesn't have a T0 command near the start of the GCode file or some other command that selects it implicitly, there will be no tool selected.
              mrehorstdmd 1 Reply Last reply Reply Quote 0
              • mrehorstdmd
                mrehorstdmd @dc42 last edited by
                @dc42 That sounds about right. I'll check the config files tonight. I may not have a cancel.g file. Thanks!
                • mrehorstdmd
                  Sure enough, it was missing the cancel.g file. Problem solved. Thanks!
