    Unable to print G Code files.
    Duet Web Control
    1211
    • hussainsail2002
      hussainsail2002 last edited by
      I have wired my Duet wifi Board and I am able to Jog the machine and control everything through the web browser. Everything works fine. When I try to print though it gives me the following error.
      M32 "3DBenchy.gcode"
      GCode file ""3DBenchy.gcode"" not found
      Failed to open file "3DBenchy.gcode"
      I feel like I am missing something basic.
      Hussain
      JoergS5 1 Reply Last reply Reply Quote 0
      • JoergS5
        JoergS5 @hussainsail2002 last edited by JoergS5
        @hussainsail2002 There are a few M32 related threads here and you can find them by searching. One try you can make is to add a / in front of the filename (after the double quote), one other reason is release related, so please tell the firmware and DWC version. Another reason could be using the wrong sd card, please check https://forum.duet3d.com/topic/3166/m32-gcode-file-hindge-gcode-not-found/2
        Another possibility is that (if you use windows), an editor added .txt to the filename.
        • hussainsail2002
          @JoergS5
          Thanks for the reply.
          The firmware version is: 1.19 and Web interface version is : 1.21.2-dc42
          Hussain
          • timcurtis67
            timcurtis67 last edited by
            Are you sure you are loading the file named "3DBenchy.gcode" onto your SD card through DWC? Is it possible that you are loading "3DBenchy.stl" instead?
            I would pop the SD card out of your Duet and put it in a computer to see if the file is loaded on it.
            • hussainsail2002
              @timcurtis67
              Yes am sure its a gcode file. I sliced it and saved the gcode on my desktop and uploaded the gcode file through the web browser.I opened the file again and cross checked again as well.
              Hussain.
              • DocTrucker
                DocTrucker last edited by DocTrucker
                Just for a sanity check I would suggest downloading the gcode file from the machine (don't just use the original file from your computer) and upload the file to the following webpage just to check it is valid:
                http://gcode.ws/
                Second thing I'd try is instead of:
                M32 "filename.g"
                Try:
                M23 "filename.g"
                ...followed by:
                M24
                Alive: 1 Ormerodish machines. 1 Custom Cantilever. 3 P3Steel. 1 Ciclopish scanner. In build: 1 P3Steel. Controllers: 2 Duet 2 , 2 D0.6, 1 D0.8.5, 1 D3 v0.5, 1 RAMPS/DRV8825, 1 Uno/Scan Card.
                  dc42 administrators @hussainsail2002 last edited by
                  @hussainsail2002, you are running an old firmware version and I think you are running a much newer version of the web browser. The old firmware doesn't accept the quotation marks that the newer web browser uses. I suggest you upgrade your main firmware to 2.02 or 2.02RC6.
                  hussainsail2002 1 Reply Last reply Reply Quote 0
                  • hussainsail2002
                    hussainsail2002 @dc42 last edited by
                    I tried Updating the firmware:
                    I downloaded the file called duet2combinedfirmware.bin
                    I opened up the web browser page and clicked on settings. In settings I clicked on upload files and chose the .bin file that I saved earlier.
                    It gave me a message:
                    "You have just uploaded a firmware file. Would you like to update your Duet now?"
                    I pressed the Yes option.
                    It then gives me the following error
                    M997 S0
                    Error: Firmware binary "DuetWiFiFirmware.bin" not found
                    Am I doing this correctly ?
                    Hussain
                      See https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_Upgrading_a_Duet_2_WiFi_or_Ethernet_to_firmware_1_21_or_later_from_1_20_or_earlier. As you have already upgraded DuetWebControl, your simplest option is to rename the uploaded file from Duet2CombinedFirmware.bin to DuetWiFiFirmware.bin. You can do this in the System Editor page of DWC. Then send M997 S0 through the GCode Console page.
                      hussainsail2002 2 Replies Last reply Reply Quote 0
                      • hussainsail2002
                        I went to the system editor page under settings , right clicked on Duet2CombinedFirmware.bin and renamed it to DuetWiFiFirmware.bin
                        When I type M997 S0 in the console I get the following error
                        M997 S0
                        Error: In-application programming binary "iap4e.bin" not found
                        • hussainsail2002
                          So I googled the problem and downloaded the file iap4e.bin and copied it to the SD card.
                          Once I got the SD card back in the board I tried M997 S0 , at first it said updating firmware so connection is closed . I then reconnected a few minutes later and typed M997 S0 and it now gives me a new error
                          M997 S0
                          Error: M997: Firmware binary "Duet2CombinedFirmware.bin" not found
                          Following are the version details that are mentioned under the settings tab
                          Firmware Version: 2.02RC6(RTOS) (2018-12-15b2)
                          WiFi Server Version: 1.19
                          Web Interface Version: 1.21.2-dc42
                          aidar 1 Reply Last reply Reply Quote 0
                          • aidar
                            aidar @hussainsail2002 last edited by
                            @hussainsail2002 said in Unable to print G Code files.:
                            M997 S0
                            You dont need this file anymore as you have now latest firmware already (2.02RC6). Now you should update wifi server and duet web control to latest also.
                            • hussainsail2002
                              hussainsail2002 @aidar last edited by hussainsail2002
                              @aidar
                              I have updated the server and web control by uploading the .bin file and .zip file accordingly.
                              WiFi Server Version: 1.21
                              Web Interface Version: 1.22.5
                              When I type M997 S0 I still get the same error message.
                              M997 S0
                              • aidar
                                As i said before - you already have latest firmware installed, forget about M997 command, go testing and printing.
                                • hussainsail2002
                                  Thank you!!
                                  I got it working !
