    Autolevel with NPN NO Inductive sensor problems
    1.7k
    • GPetropoulosundefined
      GPetropoulos
      @phaedrux Not clear to me yet. I will try with positive then first and report back.
        Phaedrux Moderator @GPetropoulos
        @gpetropoulos Yes that looks good, except that G30 won't take an F parameter. It will use the F value given in M558 in config.g. I suggested a value of 100 earlier.
        GPetropoulosundefined 1 Reply Last reply Reply Quote 0
          GPetropoulos @Phaedrux
          @phaedrux Yeah probably. I tried the 100 and was too slow. 😄 I have F1000 in my M558 and probably that is being used. I started the test print and seems to be working like a charm. 🙂
          Thank you very much. I would not manage to get it done this fast without your help. Cheers!
          Wish you the best and a Happy New Year mate.
          So for anyone confused set positive value for trigger height in G31 command!!
            Glad it's working properly now. I think the issue was a result of Z0 being set differently than what the G31 trigger height would have given, and the difference was resulting in the huge offset from the Z plane in the heightmap.
