    LCD12864 Hardware wiring
    • garlicbreadundefined
      garlicbread
      I've noticed the latest firmware now has 12864 display support
      with custom menu's which is cool
      • https://forum.duet3d.com/topic/8014/12864-display-sd-print-subfolder-screen-update
      • https://duet3d.dozuki.com/Wiki/Duet_2_Maestro_12864_display_menu_system
      I have a Duet2 Wifi 1.04 and I've got one of those cheap Smart Controller 12864 displays from amazon
      But I'm assuming you can't just connect one of those displays directly to the board though
      since level shifting between 5V / 3.3V may be required
      or am I wong and you can just wire it directly in place?
      are there any details on the wiring layout, and does the duet have 5v tolerant inputs?
      • Vetiundefined
        Veti
        see
        https://forum.duet3d.com/post/75009
        • CthulhuLabsundefined
          CthulhuLabs
          You are correct. You need to level shift the signals. The Maestro board already does this but the Duet Wifi and Ethernet do not. I am working on a board to do this and will share the design when done.
          • Cataundefined
            Cata
            Whyat firm version? I dont see any mention
              The firmware build for the Duet WiFi/Ethernet doesn't include the 12864 support. However, in firmware 2.02 I made a change to the way the 12864 display + encoder is supported to make it easier to enable in future.
                garlicbread
                thanks for the info
