    PLEASE HELP! SD Card Wiped
    • DustinDep
      DustinDep last edited by
      Hey, long story short my sd card for my duet wifi got wiped where can i get all the files i need to load back on it?
      Thanks!
      Dustin
      • SimonRafferty
        SimonRafferty last edited by
        That's odd, mine wiped itself on Monday! No apparent reason - I was printing something, it finished & I de-powered the machine for a couple of hours. Re-power and the card is completely blank!
        It was a brand new card when I installed the Duet - so only a few months old. Is there anything in the code which writes repeatedly to the card? I wondered if it could have exceeded the write cycle life?
        I'll put the card in my PC when I have time to fiddle to see if it's recoverable.
        Si
        • T3P3Tony
          Hi Dustin
          You can use the configurator to re do your configuration (https://configurator.reprapfirmware.org)
          Then tweak the configuration if you had specific changes.
          The folder structure is detailed here:
          https://duet3d.com/wiki/SD_card_folder_structure
          www.duet3d.com
          • StephenRC
            StephenRC last edited by
            This has the generic setups: https://github.com/dc42/RepRapFirmware
            • briangilbert
              briangilbert last edited by
              I can't recommend highly enough.. Make a repo on github with your own configuration!
              Co-creator of the Zesty Nimble direct drive extruder
