    M106 questions on p1 and p2
    m106 fan cooling
    • ckigarundefined
      ckigar
      RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.0(RTOS) ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-06-05b3
      When I plug my print cooling fan into P0, it doesn't respond to
      m106 P0 S255 (or s1).
      When I plug that fan into one of the 'always on' connections, it does turn (correct direction)
      The Hot end fan (p1) will turn on with m106 P1 s255 i1 (or s1)
      This is the fans section of my config.g:
      M106 P0 S255 B5 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      M106 P1 S255 B5 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
      (I do see the 'burst' of 5 seconds on p1)
      Both fans are two wire.
      The Duet is a pretty recent purchase and I am still working my way through it. I have a e3d v6 hot end (but not with the original fan, should be similar though)
      Chip Kigar
      • z97froehlichundefined
        z97froehlich
        In your config.g file, try changing your M106 commands to M106 P0 S0 I0 F500 H-1; and M106 P1 S0 I0 F500 H-1;
        https://reprap.org/wiki/G-code
        That wiki is a great source for learning about how to properly configure your printer
        • ckigarundefined
          ckigar
          @z97froehlich said in M106 questions on p1 and p2:
          Odd... p2 worked but never p0.. I'll leave this as unsolved for a day or two. No a big deal, but puzzling.
          • peirofundefined
            peirof
            Have you checked wiring.... I think ball bearing fans don't turn if they are unvertwd
              dc42 administrators @ckigar
              @ckigar, if M106 P0 H-1 S1 doesn't get the fan spinning when connected to Fan 0, but the same fan does work on the Fan 1 and Fan 2 outputs when you use P1 and P2 in the M106 command, then the Fan 0 output is faulty and you should ask your supplier to replace the Duet.
