    [bug] [workaround] reboot fails with PS_ON and berd-air
    Firmware installation
    828
    • c310undefined
      c310
      Configuration:
      DuetWiFi 1.03
      2.02(RTOS) (2018-12-24b1)
      berd-air is connected to P1
      power is controlled by non-latching "start" button as described here
      related config.g line: M106 P1 L20 X150 F22500 H-1 B0.1 S0
      What happens
      when i reboot machine either by mushroom button or by DWC "Emergency Stop" machine goes into reboot, but does not wake up after it. Reason: connected berd-air starts working at 100% , as @dc42 explained - it is safety feature . so, this air pump sucks all power off board and PS_ON realy disconnects.
      I have disconnected air pump - reboot works as it should.
      Proposed solution:
      implement a 5 seconds delay on boot before switch on any fan.
      this will save power for PS_ON relay to keep power on.
      • dragonnundefined
        dragonn
        I don't understand?
        When using PS_ON you should add an external 5V power supply to power Duet and PS_ON relay.
        c310undefined 1 Reply Last reply Reply Quote 0
        • c310undefined
          c310 @dragonn
          @dragonn it works well without 5v 🙂 see link in my post
            You could move the Berd Air to a different fan output so that is doesn't start power up.
            • c310undefined
              c310
              @dc42 said in [bug] reboot fails with PS_ON and berd-air (or other fan):
              please advise which ports start powered at board boot, and which are not.
              • aidarundefined
                aidar
                From https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_fans .
                We recommend you use the FAN1 connector for a thermostatically-controlled hot end fan, because on the Duet 2 it defaults to being on at power up, to provide maximum safety if you restart your Duet when the hot end is hot.
                deckingmanundefined c310undefined 2 Replies Last reply Reply Quote 0
                • deckingmanundefined
                  deckingman @aidar
                  @aidar Yes, but the OP is using a berd-air which is for part cooling, not hot end cooling.
                  aidarundefined 1 Reply Last reply Reply Quote 0
                  • c310undefined
                    c310 @aidar
                    @aidar said in [bug] reboot fails with PS_ON and berd-air (or other fan):
                    that helped. thank you very much!
                    • aidarundefined
                      aidar @deckingman
                      @deckingman said in [bug] [workaround] reboot fails with PS_ON and berd-air:
                      Yep i know, but his config says its connected to FAN1 connector (M106 P1.....)
                        deckingman @aidar
                        @aidar said in [bug] [workaround] reboot fails with PS_ON and berd-air:
                        Precisely!
                        • c310undefined
                          c310 @aidar
                          i swapped connectors and adjusted numbers accordingly 🙂
