    Start.g and M80
    846
    • Kimberly
      Kimberly last edited by Kimberly
      Hi all I know that this questions have been asked before,
      but I did not find the solution..
      https://forum.duet3d.com/topic/7828/problem-with-powering-on-with-m80
      My machine:
      Modified CR10S with the Duet3D wi-fi board. Firmware version 1.21 (2018-03-21)
      and a 500W ATX PowerSupply
      (The powersupply is hooked up the the EXT 5V
      (and jumper moved to allow for power on/off)
      (Using Purple Green and black from the ATX powersupply)
      so its always delivers 5V power and Pulles the ATX green wire low to power on...
      I want the M80 command to be run before the print starts..
      my slicer produces this...
      // slicer Inserted before print
      G90
      M82
      M106 S0
      M140 S74
      M190 S74
      M104 S195 T0
      M109 S195 T0
      // My start G-code.
      M80; PowerON ATX
      //as dek pointed out I would properly need to yield for some time for the stepper to power up.
      SO I will insert the G4 S5 ; Dwell for 5 seconds
      as I understand it, the M104 and M109 is yielding for heated nossel and bed.
      Stopping the ATX power from turning on..
      Dc42 pointed out the the post that there a start.g file but my understanding is that the start.g is initialised from sd card prints, and im using the Webinterface
      💕💕💕 Love you 💕💕💕
      • Kimberly
        Hi Again found the solution for a
        Simplify3d
        in my start Code I insert
        M80; Start ATX
        G4 S5 ;Yield 5 sec before continue
        M104 S[extruder0_temperature] ;Preheat Extruder
        M190 S[bed0_temperature] ;Wait for bed to heat
        M140 S[extruder0_temperature] ;Wait for Extruder
        the build in M140 and M109 will be overriden and the variables replaced on build 🥰
        thanks anyways..
        💕💕💕 Love you 💕💕💕
          If you are using Duet Web Control to start prints then you are printing from SD card and start.g will be run.
          Kimberly pro3d 2 Replies Last reply Reply Quote 0
          • Kimberly
            Kimberly @dc42 last edited by
            @dc42 hI thanks for the reply and the clarification 😄
            💕💕💕 Love you 💕💕💕
            • pro3d
              pro3d @dc42 last edited by
              Does this mean we don't have to call the start.g macro in the slicer? Sorry for interfering here but I have a start and end macro called in the slicer printing from the dwc
              Valkyrie DIY High Temp 3D Printer
              R&D - Engineering Designer - Viking 3D Printers
              https://vkingprinter.com/
              Phaedrux Kimberly 2 Replies Last reply Reply Quote 0
                Phaedrux Moderator @pro3d last edited by
                @pro3d That's right, start.g will run before any slicer start gcode when the print is started from the SD card.
                wilriker 1 Reply Last reply Reply Quote 0
                • wilriker
                  wilriker @Phaedrux last edited by
                  @phaedrux said in Start.g and M80:
                  It will be even run before the first line of GCode in the file is executed.
                  Manuel
                  My Tool Collection
                  • Kimberly
                    Kimberly @pro3d last edited by Kimberly
                    @pro3d
                    I add code to my slicer Simplify 3d
                    to start the ATX power supply
                    my code in Start scripts
                    M80; Start ATX
                    I should properly not use the M104 command but its fine..
                    heats up the nose but I will properly move it to after 😄
                    The Myyy[xxxxxX_xxxxxxx] tells simplify3D to ignore its own inserted commands.
                    so it will not insert them before you start scripts
                    💕💕💕 Love you 💕💕💕
