    fans not responding.
    2.7k
      Sure. DWC stands for duet web control. It's the web interface to control the duet.
      https://duet3d.dozuki.com/Wiki/Duet_Web_Control_Manual
      • ohluckyirishundefined
        ohluckyirish
        no the slider doesnt turn the fan on.
          So just to confirm you've switched the fan connections on the board and have made the configuration change I posted?
          You could test the fan by connecting it to the always on fan header.
          Also double check that you have the fan wires connected to the right pins. Positive and negative.
            ohluckyirish
            yes and neither fan is turning on when i have them in the always on connector
            Wyvernundefined 1 Reply Last reply Reply Quote 0
              How are you powering the Duet right now, USB, or DC power supply?
              If PSU, what voltage, 12v or 24v?
              What voltage are the fans?
              Can you test the fans by powering them directly from a DC PSU?
              Do you have a known working fan to test with?
              • Wyvernundefined
                Wyvern @ohluckyirish
                @ohluckyirish
                What voltage are you getting at always on sockets?
                If you have a Duet 2 there is a fan fuse, is it blown?
                  ohluckyirish
                  all my fans were working fine before i upgraded to the duet board.
                  • Wyvernundefined
                    Wyvern
                    Check your fan fuse.
                    Check voltage at the fan fuse to see if you have PSU voltage. (one lead on the fuse top, one to ground on the PSU)
                    Double check your polarity.
                      Which Duet are you using? What revision?
                      What firmware version?
                      Can you send M122 in the gcode console and post the response here?
                        ohluckyirish
                        == Diagnostics ===
                        RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02(RTOS) running on Duet WiFi 1.02 or later
                        Board ID: 08DGM-9T6BU-FG3S4-6J1D8-3SD6J-1VR7F
                        Used output buffers: 3 of 20 (9 max)
                        Static ram: 25524
                        Dynamic ram: 98620 of which 0 recycled
                        Exception stack ram used: 280
                        Never used ram: 6648
                        Tasks: NETWORK(ready,656) HEAT(blocked,1232) MAIN(running,3788) IDLE(ready,200)
                        Owned mutexes:
                        Last reset 00:00:19 ago, cause: power up
                        Last software reset at 2019-02-12 20:13, reason: User, spinning module GCodes, available RAM 6648 bytes (slot 2)
                        Error status: 0
                        Free file entries: 10
                        MCU temperature: min 18.3, current 21.5, max 21.8
                        Supply voltage: min 12.7, current 12.7, max 12.8, under voltage events: 0, over voltage events: 0, power good: yes
                        Date/time: 2019-02-13 17:55:58
                        Cache data hit count 63519798
                        Slowest loop: 6.96ms; fastest: 0.07ms
                        I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0
                        Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 240, MaxWait: 0ms, Underruns: 0, 0
                        Scheduled moves: 0, completed moves: 0
                        Bed compensation in use: none
                        Heater 1 is on, I-accum = 0.0
                        Segments left: 0
                        Movement lock held by null
                        http is idle in state(s) 0
                        telnet is idle in state(s) 0
                        file is idle in state(s) 0
                        serial is idle in state(s) 0
                        aux is idle in state(s) 0
                        daemon is idle in state(s) 0
                        queue is idle in state(s) 0
                        Code queue is empty.
                        === Network ===
                        Slowest loop: 22.72ms; fastest: 0.00ms
                        Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
                        HTTP sessions: 1 of 8
                        • WiFi -
                          Network state is running
                          WiFi firmware version 1.22
                          WiFi MAC address cc:50:e3:14:b7:80
                          WiFi Vcc 3.34, reset reason Turned on by main processor
                          WiFi flash size 4194304, free heap 26008
                          WiFi IP address 192.168.1.43
                          WiFi signal strength -58dBm, reconnections 0, sleep mode modem
                          Socket states: 4 4 0 0 0 0 0 0
                          ohluckyirish
                          here is what i put as my fans
                          M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, gcode control for part cooling fan
                          M106 P1 S0.5 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                            ohluckyirish
                            which position should the jumper be in ?
                              Phaedrux Moderator @ohluckyirish
                              @ohluckyirish it looks like you have a 12v power supply so if your fans are also 12v you would bridge the vin and vfan pins with the jumper to feed the fans 12 volts.
                                ohluckyirish
                                so the two pins on the right ?
                                it is currently on the Jumper: int 5V EN
                                  @ohluckyirish that's right
                                    ohluckyirish
                                    the part cooling fan came on that is plugged into the always fan port, but none of the green lights come on ?
                                      ohluckyirish
                                      is there only post to be one jumper in ?
                                        @ohluckyirish said in fans not responding.:
                                        I'm not sure what you mean.
                                          ohluckyirish
                                          i moved the jumper from the int 5v en to the v fan jumper fan select. now only the fan comes on and none of the green lights on the board come on
                                            ohluckyirish
