    Dude about fans
    • peirof
      peirof last edited by
      i have this setup for fans in config.g
       M106 P0 S1 I0 T100 H1
       M106 P1 S0.6 I0 F500 H-1
       M106 P2 S0.6 I0 F500 H-1
      When P0, its heatskin fan, that is controled by temperature, and P1 and P2, layers fans....
      The issue its that layers fans start turning....
      How i must setup layers fans, for:
      -When power on printer, rest stopped.
      • When print, are commanded by gcode printed
      From wiki:
       Px -- Fan Shocket
       S0.6 -- Run at 60%
       I0 -- Normal PWM
       F500 -- Fan PWM frequency (i dont have clear whats the meaning)
       H-1 --  Disables thermostatic mode
      Whit this setup, layer fans, start powered on.... How i can do, start powered off?
      • deckingman
        deckingman last edited by deckingman
        S0 will set zero speed (that's S zero not "so"). So if you don't want the fans to come on at power on, use S0 instead of S0.6.
        peirof 1 Reply Last reply Reply Quote 0
        • peirof
          peirof @deckingman last edited by
          @deckingman ok, thanks. Later try...
          I suppose, that these fans, will be put into operation, when the print reaches the layer in which the gcode turns them on ... No?
            Phaedrux Moderator @peirof last edited by
            @peirof said in Dude about fans:
            No?
            yes.
