    Duet wifi died last night and can't get it running again
    739
    • totalitarian
      totalitarian last edited by
      OK my printer just turned itself off last night. I have 24v power to the board but can't connect via wifi or usb. In addition to this, none of my always on fans are running.
      Any idea how to diagnose this issue please
      • totalitarian
        Reply from pronterface sending M115
        [ERROR] Can't read from printer (disconnected?) (SerialException): call to ClearCommError failed
        [ERROR] Can't write to printer (disconnected?) (SerialException): WriteFile failed (WindowsError(22, 'The device does not recognize the command.'))
        • totalitarian
          totalitarian last edited by totalitarian
          Photo of LEDs
            https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond
            totalitarian 1 Reply Last reply Reply Quote 0
            • totalitarian
              totalitarian @Phaedrux last edited by
              @phaedrux THanks, but I have already tried those steps.
              • Atelier3D
                Atelier3D last edited by
                Have you checked your fuses to see if any of them are blown?
                  dc42 administrators @totalitarian last edited by
                  @totalitarian said in Duet wifi died last night and can't get it running again:
                  All of them, including this one https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respond#Section_If_the_port_still_doesn_t_appear_on_the_PC ?
                  • totalitarian
                    Port appears but I get this reply from pronterface sending M115
                      Does it still do that if you remove the SD card and restart? You may have to wait a few tens of seconds for it to give up reading the SD card at startup.
                      • totalitarian
                        Thanks, had to reflash using SAM-BA. Now I can see the error
                        Error: short-to-ground reported by driver(s) 3
                        [ERROR] Error: short-to-ground reported by driver(s) 3
                        Error: over temperature shutdown reported by driver(s) 3
                        [ERROR] Error: over temperature shutdown reported by driver(s) 3
                          If you have a motor connected to driver 3 (the E1 E0 output), power down and disconnect the motor to avoid overheating it. Then check whether you still get the same error report, and whether the E1 E0 driver chip is getting hot.
                          • totalitarian
                            Isn't driver 3 E0 rather than E1?
                            Either way, I unplugged all drivers and still get that same error 😞
                              Correct, E0 not E1. If your Duet is under warranty, please ask your supplier to repair or replace it.
