Print problems and fixes
    Part 1 - https://streamable.com/qjwwg
    And
    Part 2 - https://streamable.com/eyphe
    See print in video link.
    First print attempt with settings:
    Tronxy x5sa
    Duetwifi
    Bed 330x330x400 pei sheet temp 20c
    Hotend temp 200c
    (Amazon Basics Premium PLA Reccomended heat 200c-230c)
    Suggestion on what to adjust?
  • Using Simplify3d Settings...
    8_1551657887843_Temperature.PNG 7_1551657887843_Support.PNG 6_1551657887843_Speeds.PNG 5_1551657887843_settingLayer.PNG 4_1551657887843_settingExtruder.PNG 3_1551657887843_Infill.PNG 2_1551657887843_GCode.PNG 1_1551657887843_Cooling.PNG 0_1551657887842_Additions.PNG
  • The first things I would do is make sure the bed is clean (glass cleaner), carefully check that my extruder barely touches the bed at zero (I see you have a probe, maybe recheck the Z offset). If you raen't using that for mapping, make sure the bed is level across and at all 4 corners. These are the things that always bite me, not Cura or Simplify (have not used the others in a long time).
    Of the settings you have that I think significantly differ from mine are that I use a bed temp of 50 C. I also use a thinner first layer, 50% or 75%.
    • Wes
    p.s. Not sure what the object was. I don't usually use rafts, I try to design my way around them. I do always use a skirt to help make sure the extruder is pumping well before it prints the first layer.
  • @wes-howe Using brand new PEI Sheet. Its clean.
    Bed Temp has no effect. sticking fine to bed.
    My offset is showing...
    M98 P"0:/macros/G30 S1"
    Stopped at height 0.967 mm
    So i have this in my config.g
    G31 P25 X-20 Y-45 Z0.97 ; Set Z probe trigger value, offset and trigger height
    First Layer Looks fine, its the subsequent layers that is out of whack.
    @chriskimbr said in Print problems and fixes:
    Have you checked that you have the correct Z steps/mm value, so that when you command the head 50mm up it really does move 50mm?
    Also, what hot end thermistor does your printer use, and what M305 P1 settings do you have in config,g?
  • Moderator
    Is your thermistor configured correctly?
    Have you done a PID tuning of the hotend?
    Have you calibrated e steps per mm?
    Is the cooling fan duct blowing onto the print or onto the hotend?
    That's a very small object to print at 80mm/s base speed.
    Maybe include you config.g?
  • @dc42 Have you checked that you have the correct Z steps/mm value, so that when you command the head 50mm up it really does move 50mm?
    How and where do I check the z steps value?
    I got a thermistor from Local store, no paperwork, he said it was standard 100k thermistor.
    Config.g
    ; generated by RepRapFirmware Configuration Tool v2 on Sat Feb 09 2019 18:37:46 GMT+0000 (GMT)
    M667 S1 ; Select CoreXY mode
    M550 P"TronXY X5SA" ; Set machine name
    M552 S1 ; Enable network
    M586 P0 S1 ; Enable/Disable HTTP S0=disable S1=enable
    M586 P1 S1 ; Enable/Disable FTP
    M586 P2 S1 ; Enable/Disable Telnet
    M569 P0 S0 ; Drive 0 goes backwards
    M92 X80.00 Y80.00 Z400.00 E96.00 ;steps per mm
    M566 X900.00 Y900.00 Z12.00 E500.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z180.00 E3000.00 ; Set maximum speeds (mm/min)
    M201 X1500.00 Y1500.00 Z20.00 E800.00 ; Set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X330 Y330 Z400 S0 ; Set axis maxima
    M574 X1 Y1 S0 ; Set active high endstops
    M574 Z1 S2 ;Define Z to use Probe. Home to Min.
    ;M591 D0 P2 C3 S1 ; Filament sensor on for E0 extruder, simple NO switch connected to E0
    M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
    M558 P9 H5 F100 T2000 ; Set Z probe type to bltouch and the dive height + speeds
    ;G31 P25 X-20 Y-45 Z0.475 ; Set Z probe trigger value, offset and trigger height
    ;G31 P25 X-20 Y-45 Z1.2132 ; Set Z probe trigger value, offset and trigger height
    M557 X30:315 Y15:315 S75 ; Define mesh grid
    ;M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
    M305 P1 R4700 T100000 B4388 ; set E0 thermistor parameters
    M563 P0 D0 H1 ; Define tool 0
    If it's a standard Chinese thermistor then this line won't give accurate temperatures:
    Try changing the B parameter to B3950. This still won't be very accurate, but it will give the same results as Marlin temperature table 11, which is what most 8-bit controllers use with this type of thermistor.
  • Hi, I have same printer. I notice your stepper currents are set at 800. If you original steppers from tronxy they have maximum current rating of 1.68 so yours should be set at 85% which is just over 1.4.
    @chas2706 said in Print problems and fixes:
    I don't know that printer, but if the motors are attached to plastic parts then you may find that at 1.4A the motors get hot enough to soften the plastic. I find that 1.68A motors run well enough at 1.0A or 1.2A in my printers.
  • Thank you for that dc42. I shall reduce mine.
    By the way, this board is the bee's knees and your commitment to it and the forum are outstanding.
  • @dc42 Sorry forum won't let me uncomment this line says its spam.
    Ive been using this line ...
    Do i need the C7.060000e-8 value?
    I got this from someone elses config and am not sure if i need it or what to set mine at.
  • have you checked that all of you axis are going the proper distances (step per mm). you can check by jogging the tool head along a ruler so you don't have to run a print.
    I ran this command to do the PID test.
    M303 H1 S240
    What does this mean? what to do next?
  • Moderator
    https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
    After running the tuning M500 will save the results to config-override.g and then you must add M501 to config.g to load config-override.g at startup.
  • check relative extruder, you never know
  • @nicolab28 said in Print problems and fixes:
    Certainly check extruder e-steps but absolute or relative extrusion doesn't have that much effect.
  • On one of my printer, the nozzle closes continuously, and checking this box, no more worries.
    He has an M83, and S3D gives him an absolute gcode
  • @dc42 I stuck a ruler and moved x, y , z. spot on.
  • @phaedrux Is this where are you seeing 80mm/s base speed?
    Whats the difference, Don't they both set the microstepping speed? does one override the other? what is the correct speed to have with my issues?
  • Moderator
    No I got it from your screen shot from S3D here:
    4800mm/min = 80mm/s
  • @phaedrux said in Print problems and fixes:
    M500
    Where in the config.g file do i put the M501 ?
    Any parameters after the M501...?
  • Moderator
    Those settings look to me like settings intended for the 104GT2 thermistor used in E3D hot ends, but they are not correct even for that one.
