Core-XY based on Rat Rig V-Core and Duet 2 Ethernet
the site says since they manufacture each plate individualy they can make it to your likeing. so 320x320x8 should also work
I have seen that, the 320x320 is just a figure out of my head, I have to wait till the V-Core kit has arrived to see exactly how big I can make it. But definitely a good place to check out. Also they do laser cutting, good to keep that in mind for the enclosure at the end of this project.
Jan
I got my tooling plate from Ecocast tooling plate not to bad on pricing and very quick (Carriage is the killer but get manageable if you want a lot of stuff as it is a fixed rate)
If you want it customised to a specific shape etc then I would suggest getting it water jet cut so as to not induce any real temp change which may just shock it to warp although I think that is unlikely to happen but you never know.
My Silicon Heater is from Keenovo and I can say they are the best of the chinese makers having had several of them now. they will make it with holes in them wherever you want them ie for mounting holes and in my case I have a 10 mm hole in the centre of them that way I can drill a 3mm hole that doesn't quite go thru the ally bed and then I glue in a temp sensor using Arctic Silver thermal epoxy.
HTH
Doug
Also added to my link list. deckingman also recommended the Keenovo heaters, I have looked at them and they do a great variety of them, the price is very good (Customs or at least VAT will be added on arrival). My main concern is the adhesive, but it must be good otherwise it was not recommended I guess.
Jan
@snoozer said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
I have flicked through some of your YT videos. Man what a machine !!!! The dynamic counter weight is absolutely stunningly well done and is works so well.
Thanks for the complement. Don't get too excited about the dynamic load balancing though. Although it does a good job of stabilising the printer as a whole, there is no improvement in print quality. That's because the frame is very stiff so although the entire printer rocks about, everything rocks together so there is no adverse effect on print quality to start with. It's a solution to a problem that doesn't exist on my printer and I was stupid in not evaluating that at first. But I always share my experiences, both good and bad, on my blog as it might help others. So, if you have a stiff frame, don't bother trying to cancel out the forces. If you have a frame that can "flex" and you get problems with prints because of that, then this might be worth a try.
I have a steel table welded for my Prusa MK3, that's over 50kg. The high mass has reduced the set-up rocking about a lot. I can see what you mean re stiffness, and I would also not have 4kg of moving mass on my printer, at least not on the V-Core I am building now. But to come up with the idea is pretty fascinating. What steppers do you use for your XY axis ? Are they driven directly from the Duet or do you have external drivers ?
Jan
Just in case ppl are interested, my preliminary idea of a hotend mount for my V-Core is here:
https://www.thingiverse.com/thing:3490910
It is UNTESTED so far, I only worked of the original V-Core Fusion 360 files. I don't even have the V-Core kit yet on hand.
Jan
@deckingman
What steppers do you use for your XY axis ? Are they driven directly from the Duet or do you have external drivers ?Jan
Nema 17s driven from the Duet. Rated current is 2.0 Amps and I run them at 1800mA. Bear in mind that I use two separate XY gantries - one for the hot and and one for the extruders. So my 4kgs of mass is spread across two gantries and thus 4 motors.
(The load balancing is yet another XY gantry with yet another 2 motors).
Jan
Not only do Keenovo do a great variety but they will also do you a custom one if you so wish. I now get mine without Temperature sensors in them as I prefer to use my own.
Doug
Ratrig offers an anodised alluminum 3mm bed in the kit. As far as i have used it, it seems great. Plus anodising makes it insulated.
Just watched your video of the 5x BT extruder upgrade. Its all V-Slot mechanics your are using ? Must be a good system if you are still with that. I have read about ppl having issues with flats spots on the wheels when the printer is sitting for a while, you never had that ? Did you deliberately chose to load the wheel lateral on the X axis or did your design just work out better with the space you have available this way and the loading direction is accidental ?
I did check the Aluminium supplier you suggested, no shipping to IRL, same with a couple of other suppliers from the UK. A friend of mine lives part time in Newcastle, I get him to bring one back for me. The price really is reasonable in compare to what I find local.
How is your glass plate held in place ? It looks almost as if you have a slot in system ?
Thanks
Jan -
@snoozer So many questions ....
Yes it's all OpenBuilds Vslot.
No, I've never had a problem with flat spotting the wheels. There is only one reason why that can happen and that is if the wheel doesn't rotate freely and scrapes along the rail. It's exactly the same as locking the brakes on a car (before the days of ABS) and then the tyre scrapes along the road.
IMO there is only one reason why the wheels may not rotate freely and that is due to poor assembly. The eccentric spacers must be adjusted so that when a carriage is fitted to a rail, if that rail is then tilted, the carriage will slide under it's own weight. At the same time, there must be no "play" in the carriage.
I have had occasions when using OpenBuilds gantry plates, even with the eccentric spacers backed off completely, the carriage is still too tight. That is an unacceptable situation. One solution that I have used is to enlarge the small hole that takes the wheels on the other side of the gantry plate. This allows the bolt with the non-eccentric spacers to move slightly further away from the rail which then gives the necessary clearance. One other thing that can make the wheels bind is over tightening the lock nuts. However it is achieved, the wheels must rotate freely on the rails and not bind.
Regarding the lateral loading of the wheels on the X carriage, I guess you mean the fact that the wheels are either side of the rails, rather than being top and bottom. There are three reasons for this. One being that I use two parallel rails. The carriage has 6 wheels in total, 3 per rail with two inner fixed wheels, and one outer adjustable wheel. This arrangement helps to keep the rails parallel. The second reason is that I always like to have the wheel bolts supported both ends, like an axel. Rather than having the bolts fixed at one end only, which means that they could flex. So it's easier to have a top and bottom plate with the "axels" fitted vertically between them, rather than using a single plate which would need bosses hanging down to support "axels" running horizontally. The third reason is that with wheels top and bottom, the hot end would have sat too high unless I had spaced the rails further apart to allow it to sit lower. This would have meant losing even more Y travel. Although the engineer in me would have preferred to have the wheels top and bottom, this works well enough.
The glass is clamped to the bed using two "L" shaped sections of aluminium extrusion. These have slots in the side through "T bolts" screw into the edge of the aluminium plate. So I press down in the extrusions then tighten the bolts.
Hope that all makes sense.
@deckingman said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
Don't forget junk bearings! Though far less likely on a good quality OpenBuilds wheel.
Thanks for the info. I can't wait to get the V-Core kit, its two weeks now I think since I ordered, I hope they will ship it next week. I will find out how well its designed then regarding tolerances and stiffness.
After watching the YT video with the Bondtech extruders I had a nosy on their website, they do pretty nice stuff, Bondtech just was never on my radar.
Jan
@snoozer I did find that when I ordered my first lot of VSlot from RatRig, that delivery wasn't as quick as I would have liked. Subsequently, I've bough all my OpenBuilds stuff from Ooznest here in the UK. That doesn't help you though......
@phaedrux said in Core-XY based on Rat Rig V-Core and Duet 2 Ethernet:
Well I wouldn't want us to fall out over it, but I'd argue that fitting junk bearings falls under the heading of poor assembly. Junk bearings seldom start life as being smooth and perfect and then fail a short time after - they are usually junk to start with and it's pretty easy to tell. Likewise Delrin wheels can sometimes have seams or casting marks that need to be dealt with by the application of fine grit abrasive. Washers and other metal parts can have burrs which need to be removed. Bits of swarf or grit can sometimes be found and need to be removed. For sure these things could all come under the heading of "defective parts" but they should be checked and either discarded or rectified as part of the assembly process in my opinion.
I got my steppers, Duet 2 and Titan Aero from Ooznest, they don't have a V-Core kit and as a 1st self build I thought I go with a mechanical kit to not get lost in my project....... Once I get all work OK I will check what path to take next. I have my eye on getting a CNC mill, but that's not yet a fully formed plan, just an idea to have better resources for future builds..........
Jan
@snoozer I have found the service from Ooznest to be first class and have no hesitation in recommending them. Of course, they don't do a 3D printer kit so I understand why you chose RatRig.
Re CNC mill. I guess it depends a lot on what you want to do with it. Most of the OpenBuilds designs that I have seen are more what I would call CNC routers, rather than milling machines. For operations such as drilling, you need a lot more Z travel. I'd be a bit concerned about the rigidity of the column on those OpenBuilds designs that I've seen which have a reasonable amount of Z travel.
If a router type CNC mill will do what you want then fine - go for it. If you want to do more than mill slots and shapes, then I think you need cast iron slide ways, with "T" slots that you can clamp a vice to, a very rigid column, precision ground spindle, adjustable jibs, etc. Personally, I need to machine mostly small aluminium or brass components and for my usage case I'm looking at buying a "proper" milling machine then maybe converting it to CNC at a later date. The conversion shouldn't be difficult - at least for a 3 axis machine. It's more less just a matter of replacing the hand wheels with stepper motors I'd have thought.
So I checked with Rat Rig last WE, they came back to me and the V-Core kit is apparently shipping this week. I hope the wait has an end soon now......
... machine then maybe converting it to CNC at a later date. The conversion shouldn't be difficult - at least for a 3 axis machine. It's more less just a matter of replacing the hand wheels with stepper motors I'd have thought.
Slightly OT now, but, have had the same thought - seems the low end machines come with lead screws instead of ball screws so may have to replace the screws or accept some backlash. At least that was my conclusion.
