    SOLVED Heating fault on heater 1, temperature excursion exceeded 15.0°C
    366
    • AimRabbit
      AimRabbit last edited by
      Hello again,
      the problem is that the hot end increase the temperature really fast and don't stop if it matches the set print temperature.
      I took a look at the wiki but I didn't understand it that much.
      I set up 180°C it passes the 180°C and goes higher and higher until I pushed the emergency button. it increases in maybe 15 seconds to 285°C.
      Some information about the printer:
      Tronxy X5S
      Duet 2 Wifi v1.04
      PanelDue 7i
      PSU 24V
      Firmware 1.22.1
      If someone could help with that would be very kind.
      Kind regards
      AimRabbit
        Is the heater cartridge for 12v or 24v?
        AimRabbit 1 Reply Last reply Reply Quote 0
        • AimRabbit
          AimRabbit @Phaedrux last edited by
          @phaedrux said in Heating fault on heater 1, temperature excursion exceeded 15.0°C:
          I think its for 12V. Is there something that I can do?
            dc42 administrators @AimRabbit last edited by dc42
            @aimrabbit said in Heating fault on heater 1, temperature excursion exceeded 15.0°C:
            If you are running a 12V heater cartridge with 24V power: don't! Some may tell you that you can set a PWM limit, but it's still a serious fire risk. Buy a 24V heater cartridge.
            You can tell if it's 12V or 24V by measuring the resistance. For a typical 35W to 40W heater, a resistance of about 4 ohms means 12V, and about 16 ohms means 24V.
            • AimRabbit
              AimRabbit @dc42 last edited by
              @dc42 oh ok I think than I have also to send back the chimera that i bought 😞
              Thanks a lot I order it right now 🙂
                Ask E3D or their distributor if you can just swap the heater cartridge they supplied with the Chimera for a 24V one.
                AimRabbit 2 Replies Last reply Reply Quote 0
                • AimRabbit
                  @dc42 did that also infect the heating bed? only to be sure that I don't must order a new one too.
                  • AimRabbit
                    @dc42 said in Heating fault on heater 1, temperature excursion exceeded 15.0°C:
                    I will do that thank you a lot.
                    • AimRabbit
                      There are no words to describe how thankful I'm for your hint. I make some research and found that "2x30W Heater cartridges (12V/24V)" I think that means it supports both so i can change the hot end and kick that tronxy shit away.
                      Hopefully I get my first print after that.
