    Mesh Bed Compensation and Bed Leveling
    • KnineDHPundefined
      KnineDHP
      I have a Railcore and something is not working with bed leveling and the Mesh grid. both my right sides are -Z and both the left are +Z the bed leveling should fix this. i will post the configs below.
      What i don't understand is why is it not just lowering the left or raising the right to get it closer?
      Thank you all in advance for looking at this.
      config.g
      Bed.G
      M561
      G30 P0 X10 Y48 Z-99999
      G30 P1 X10 Y254 Z-99999
      G30 P2 X300 Y185 Z-99999
      G1 X0 Y0 F5000
      Prep to print script
      G28
      G32
      G32
      G32
      G28 Z
      G91
      G1 Z5
      M557 X48:254 Y48:254 S206
      G29
      G28 Z
      Result of the mesh output
      Front left X48 Y48 Z0.051
      Rear Left X48 Y254 Z0.031
      Front Right X254 Y48 Z-0.035
      Rear Right X254 Y254 Z-0.082
      • KnineDHPundefined
        KnineDHP
        Any thoughts? Days of trying and I can't solve for this.
          Can you post your homing files? and your Bed.g? Maybe also config?
          KnineDHPundefined 1 Reply Last reply Reply Quote 0
          • KnineDHPundefined
            KnineDHP @Phaedrux
            @phaedrux Bed.G and config.G are in the original post. Here are all the home files.
            Thank you
            homez.g
            homey.g
            homex.g
            homeall.g
            config.g
            bed.g
            • KnineDHPundefined
              KnineDHP
              I think i found it i at some point lost a S3 in bed.g
                dc42 administrators @KnineDHP
                @kninedhp said in Mesh Bed Compensation and Bed Leveling:
                That would explain it. Without S3 on the last G30 command, it won't adjust the leadscrews.
                Also I notice that both the last two G30 lines in bed.g use P2. So the 4th point will overwrite the 3rd one. Change P2 to P3 on the last G30 command (as well as adding the S3 parameter)..
