SOLVED BL-Touch and two endstop switches
  • Hi, I have installed Independent Z motors and endstop switches on my CoreXY and it is working well. But is there a way to use this setup and BL-Touch?
    Endstop switch to tram the bed and BL-Touch to compensate for error on the build plate?
  • Moderator
    Yes you can do that. You could modify your homing script to do it all. Or perhaps split out the lead screw leveling into bed.g (G32) and then use the BLTouch for homing.
    You can use the M558 command to configure your probe and endstops right before you use them.
    It's up to you if G30 and the BLTouch is used to home Z.
    How are you currently homing and leveling? Can you post your files?
  • Thank you for replying.
    For now I am using manual leveling. Here are my files:
    Duet2 Eth.
    Firmware Version: 2.01(RTOS) (2018-07-26b2)
    Web Interface Version: 1.21.2-dc42
    M667 S1 ; Select CoreXY mode
    M550 P"RatRig" ; Set machine name
    M552 P192.168.1.14 S1 ; Enable network and set IP address
    M553 P255.255.255.0 ; Set netmask
    M554 P192.168.1.254 ; Set gateway
    M586 P0 S1 ; Enable HTTP
    M586 P1 S0 ; Disable FTP
    M586 P2 S0 ; Disable Telnet
    M569 P4 S1 ; Drive 4 goes forwards
    M350 X16 Y16 Z16 U16 E16 I1 ; Configure microstepping with interpolation
    M92 X80.00 Y80.00 Z400.00 U400.00 E430.00 ; Set steps per mm
    M566 X600.00 Y600.00 Z12.00 U12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
    M203 X18000.00 Y18000.00 Z180.00 U180.00 E1500.00 ; Set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 U20.00 E10000.00 ; Set accelerations (mm/s^2)
    M906 X1200.00 Y1200.00 Z1200.00 U1200.00 E1200.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X0 Y0 Z0 U0 S1 ; Set axis minima
    M208 X300 Y300 Z300 U300 S0 ; Set axis maxima
    ;DUAL Z
    M584 X0 Y1 Z2:3 U3 E4 P3
    M574 X1 Y1 Z2 U2 S1 ; Set active high endstops - Endret Z og U fra 1 til 2
    M558 P0 H5 F0 T6000 ; Set Z probe type to switch and the dive height + speeds
    G31 P500 X0 Y0 Z0 ; Set Z probe trigger value, offset and trigger height
    M557 X15:15 Y15:195 S20 ; Define mesh grid
    M305 P1 T100000 B4138 R4700 ; Set thermistor + ADC parameters for heater 1
    M563 P0 D0 H1 ; Define tool 0
    ; Automatic power saving
    M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss
    ; homeall.g
    ; called to home all axes
    ; generated by RepRapFirmware Configuration Tool v2 on Tue Jan 29 2019 20:37:16 GMT+0100 (sentraleuropeisk normaltid)
    G91 ; Relative positioning
    G1 S2 Z2 F6000 ; Lift Z
    G1 S1 X-305 Y-305 F3000 ; Course home X and Y
    G1 S1 X-305 ; Course home X
    G1 S1 Y-305 ; Course home Y
    G1 X4 Y4 F600 ; Move away from the endstops
    G1 S1 X-10 ; Fine home X
    G1 S1 Y-10 ; Fine home Y
    G91 ; relative positioning
    G1 S2 Z2 F6000 ; lift Z relative to current position
    M584 Z2 U3 P4 ; split Z motor control to Z and U for it to work we have to show U (param P4) in the UI
    G1 S1 Z-305 U-305 F1000 ; Move Z and U down until the switches triggers
    M584 Z2:3 P3 ; back to combined axes and hidden U
    G90 ; Back to absolute positioning
    G92 Z0 ; Tell the firmware where we are
    ;G91 ; relative positioning
    ;G1 Z10 F1000 ; lift Z relative to current position
    ;G90 ; absolute positioning
    ;G92 Z0 ; set Z to axis minimum (you may want to adjust this)
    ;G1 S2 Z5 F100 ; lift Z relative to current position
    ; homez.g
    ; called to home the Z axis
    ; generated by RepRapFirmware Configuration Tool v2 on Tue Jan 29 2019 20:37:17 GMT+0100 (sentraleuropeisk normaltid)
  • Moderator
    So you could leave your current homing files as is to level the bed if you wish, and configure the BLtouch in your config.g. that would allow the BLTouch to be used for G29 mesh compensation.
    If you wanted to use the BLTouch also for homing Z, you could add a section below the G92 Z0 to raise the Z axis, move the probe to the center of the bed, and then issue G30 to probe the bed and find the z height.
  • Thank you, I will try this.
  • @Phaedrux
    to have the above bltouch function as the z endstop only when a home all or x,y,z is homed.
    what needs to be changed, i tried the above and it just freezes.
    can you show me?
    ;M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
    M950 S0 C"!exp.heater7" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X0 Y0 Z4.222 ; set Z probe trigger value, offset and trigger height
    M557 X70:400 Y180:500 S100 ; define mesh grid
    ; HOME ALL
    ; BLTOUCH PREP
    M400 ; wait for current moves to finish
    G4 S1
    M280 P0 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
    G4 S1
    M402 ; Retract probe just in case it's down
    G1 H2 Z10 F800 ; lift Z relative to current position
    G1 H1 X-445 Y540 F1800 ; move quickly to X or Y endstop and stop there (first pass)
    G1 H1 X-445 F1800 ; home X axis
    G1 H1 Y540 F1800 ; home Y axis
    G1 X5 Y-5 F800 ; go back a few mm
    G1 H1 X-445 F200 ; move slowly to X axis endstop (second pass)
    G1 H1 Y540 F200 ; move slowly to Y axis endstop (second pass)
    G1 H1 Z-905 F400 ; home Z axis
    G1 Z5 F800 ; go back a few mm
    G1 H1 Z-905 F100 ; move slowly to Z axis endstop (second pass)
    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    G1 Z10 F800 ; lift Z relative to current position
    im such a pain in the ass but im learning 😉
  • Moderator
    @tracar said in BL-Touch and two endstop switches:
    You're using the commands to home Z using an endstop here. You should be using G30 to call for a Z probe move. Position the probe with a G1 X Y move first.
    See the examples here: https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_Homing_Z
    If you have further questions, please start a new thread.
