    Communication timeout with Repetier Server
    duet maestro duet wifi communication timeout repetier server touch console buffer reset
    • CR3Dundefined
      CR3D
      Hi Guys,
      I use Duet Wifi and Maestro in combination with a Repetier Server Touch Interface.
      I really often have problems with an stopping extruder. When I take a look in the console I can see the communication timeout like in the picture.
      What´s the problem here?
      Christian from CR-3D
      Homepage:
      www.cr-3d.de
      Facebook:
      https://www.facebook.com/cr3d.official
      Our Discord Server
      https://discord.gg/SxRaPNuRdA
      Thingiverse Profile:
      https://www.thingiverse.com/cr-3d_official/about
        See https://duet3d.dozuki.com/Wiki/Spurious_heater_faults_and_how_to_avoid_them.
        • CR3Dundefined
          CR3D
          Thank you @dc42 🙂
          But ist the communication timeout also a problem with the heating fault?
          My main problem is the timeout... 😞
          To the heating fault
          -> I have done a Auto PID tuning
          -> I use a silicone sock
          -> Temperature is really stable
          Homepage:
          www.cr-3d.de
          Facebook:
          Our Discord Server
            The heating fault occurred nearly 2 hours before the communications error.
            In recent firmware versions, the default behaviour when there is a heating fault is to give you a few minutes to sort it out, and if you don't then it assumes the machine is unattended and tries to shut it down.
            • CR3Dundefined
              CR3D
              Yes that´s right.
              So whats the problem for the communication timeout?
              The heating fault is a seperatly thing in my eyes...
              Homepage:
              www.cr-3d.de
              Facebook:
              Our Discord Server
                You have some other problems. Twice there is the sequence:
                es after '''S''', expected 3
                Done!
                Response while disconnected:
                The first line is probably part of an error message from the Duet, but Repetier has chopped off the first part. I've no idea about "Done!" but I think that's from Repetier, not the Duet. After that, Repetier seems to think it shouldn't be connected and is surprised to see a response.
